Author Topic: SIGLENT SDS3034X HD rate of rise measurement  (Read 403 times)
Offline BaNaN85Topic starter
« on: September 06, 2024, 08:28:24 am »
Hi
I need some help.
I'm using the scopes automatic measurement function, looking at the 10-90% rise time measurement.
The measuement is super off. It is not showing correct at all.
A LeCroy wavesurfer is showing ~575ns 10-90% measurement which is pretty accurate compared to manually measuring with cursors.
The Siglent scope is showing 260-300ns using the 10-90%  measurement
I try to change the threshold values between % and absolute values, no difference
I change the amplitude strategy between histogram and MAX-MIN values, no difference
I go to Analysis and change the analysis gate, no difference
I go to Analysis and change the histogram gates, no difference
Also the measurement values is constantly jumping on the y-axis
This is like the most standard easy measurement and this scope can't do it
Re: SIGLENT SDS3034X HD rate of rise measurement
« Reply #1 on: September 06, 2024, 08:54:32 am »
Ok,
So I tested another scope we have, same 10-90% measurement and that one shows correct.
So I copy that ones setup to the scope showing wrong but still same. It cannot measure 10-90%.
Doing a self calibration right now....
Offline Martin72
  • Testfield Technician
« Reply #2 on: September 06, 2024, 09:03:47 am »
Why not using the screenshot fumction ?
The following users thanked this post: egonotto, tautech
Offline noisyee
  • Country: cn
« Reply #3 on: September 06, 2024, 09:45:02 am »
That's weird.
Try to set Cursors Mode to Measure, it will show you how the measured value come from.
That may give more information to find out what's going wrong.
« Reply #4 on: September 06, 2024, 10:29:25 am »
Ok, after 1h selfcalibration over lunch the bad oscilloscope still showed wrong read on the rise times.
I hooked up the good one and recorded with cursors on measure on CH2 rise time.
Then I connected the bad scope and wanted to record how that ones cursor measure behaved.
After restarting the bad scope, the measurements seem to work fine...
Check pictures attached now
« Last Edit: September 06, 2024, 10:32:58 am by BaNaN85 »
