Author Topic: Siglent SDS7000A 3 and 4 GHz 12 bit DSO's  (Read 25483 times)
Offline Sighound36
Re: Siglent SDS7000A DSO's coming
« Reply #75 on: February 24, 2023, 06:40:58 pm »
Ethernet 1000base etc/DDR/TDR and the dual Spectrum II app is a nice as well SMPS testing with the DL-ISO Probe, FPGA' rail noise plus some emc immumity testing. The Waverunner HD is actually great for audio and power supply testing 200Mhz is really all you need for that.
I'm up for doing a back to back on the bigger BW Siglent 7000, haven't had a scope shoot out in a while, trying to accquire one of the new R&S 12 bits units. Though a few of the chaps I know with them have reported a few bugs that need ironing out shall we say, but are complimentry other wise
We have been that busy I haven't even unboxed the new  Wavepro HD yet, will rectify that this weekend  :palm:
Offline Martin72
  • Testfield Technician
« Reply #76 on: May 22, 2023, 10:57:08 pm »
Pushing this thread...
Is there any news about the progress of the SDS7000A ?
I am very curious about the targeted prices for it.
We had paid close to 14000€ in 2019 for a Lecroy HDO6034A (intel i5 cpu, 16GB DDR4 RAM, Windows 10), 12 bit native resolution and decoder/analyzer options....
Online tautechTopic starter
« Reply #77 on: May 23, 2023, 05:45:15 am »
Means nothing unless we know the model CPU.  :P
Looking up the one stated to be used in SDS7000A gives a CPU Benchmark of 6162.
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i3-8100+%40+3.60GHz&id=3103
Avid Rabid Hobbyist
Offline Martin72
« Reply #78 on: May 23, 2023, 10:40:53 pm »
Rob....Seriously ? ;)
The minimum configuration in lecroy pc-based scopes is a i5 4 core cpu with 3.2Ghz, except the hdo4000 series which got the lower i3 class onboard.
Btw, it is interesting that siglent is using a 6 year old cpu in their current scope under development - chances are that this cpu will be obsolete before the scope is released.
But if they have bought enough of them... ;)
Either way, it will definitely be a "pro" scope, at "pro" prices.
« Reply #79 on: May 24, 2023, 12:40:14 am »
This ^ you did not say however it means little unless we know the exact model CPU used so we can benchmark it.  ;)
I run i3, i5 and i7 CPU's in benchtops that unless they are heavily loaded you cannot spot the differences in performance as they all boot W10 from a SSD. The best benchmark of which is a i7 in a tiny mini PC, a ASROCK Jupiter however it runs M.2 SSD, faster than any SATA memory.
I suspect a modern DSO design running a multiple core CPU is unlikely to suffer much in they way of performance hits running any of the above CPU's. IMO reliability, CPU heat generated and fan noise is of greater concern.
I look forward to seeing the developers choice of HW in action.
« Last Edit: May 24, 2023, 12:41:48 am by tautech »
Avid Rabid Hobbyist
« Reply #80 on: June 26, 2023, 07:35:34 am »
Shahriar has a quick peek at this model at IEEE Microwave Symposium 2023.
https://youtu.be/JmB1Exhz1HQ?t=1375
Avid Rabid Hobbyist
The following users thanked this post: Performa01, egonotto, 2N3055, Martin72
Offline Martin72
« Reply #81 on: June 27, 2023, 09:22:05 pm »
I'm really curious to see how much it will end up costing.
I came to Siglent "back then" because I wanted to have good quality at an affordable price - and I can't afford a Lecroy.
For me it was a stroke of luck with the SDS touchscreen scopes, they do not have to hide, in total I consider them the best in their respective price range.
To date though, none of them come close to a lecroy PC based scope.
Which is not tragic, because they cost quite a bit more.
If Siglent then calls up the same prices as a Lecroy would cost, then there must already be weighty advantages that one then does not take the "original".
And I don't even mean the bandwidth.
As I said, I am curious. ;)
Offline Martin72
« Reply #82 on: October 04, 2023, 10:46:50 pm »
Backside of the beast, taken from the manual:
https://www.siglent.com/upload_file/document/SDS7000A_UserManual_CN01A.pdf
At least three fans... :scared:
Offline KungFuJosh
  • TEAS is real.
« Reply #83 on: October 05, 2023, 12:06:06 am »
Well, that's clearly PC based. Check out the connections panel...
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline Sighound36
« Reply #84 on: October 05, 2023, 08:06:06 am »
I will be testing one out Vs one of the Wavepro HD's we have so I report back on that in the not to distant future.
The Wavepro HD also have three deep fans inside the unit.
Cost wise my feelings are starting about £15-£17k
Offline Martin72
« Reply #85 on: October 05, 2023, 08:41:25 am »
For the H10 Version I could believe this.
For the H12 Version......12 Bit and still (?) 20GSa/s, I think it will start with a "2" as the first number.
« Reply #86 on: November 06, 2023, 02:31:48 am »
Release is just some 2 weeks away......
Only 3 and 4 GHz models will be available to the west.
Specs:
Avid Rabid Hobbyist
The following users thanked this post: 2N3055, Martin72, luudee
Offline Martin72
« Reply #87 on: November 06, 2023, 09:38:48 pm »
12 Bit and 20GSa/s...This is a beast.
Any guesses about the "entry-price" ?  ;)
My guess: 15k€ minimum without VAT.
« Reply #88 on: November 06, 2023, 10:12:22 pm »
Sighound36 was closer....for the 12 bit 3 GHz model....let's say a little under $20k.  :-X
We don't have to wait long now.
Avid Rabid Hobbyist
Offline Martin72
« Reply #89 on: November 06, 2023, 10:21:29 pm »
Yepp, makes more sense.
I'll never be able to afford it, but I'm pleased for siglent that they can offer something like this.
No one can say anymore that they are not one of the "A-brands".
« Reply #90 on: November 06, 2023, 10:35:29 pm »
12 bit, new Siglent acquisition system, 1M WFPS and 1 GB mem option is a lot to deliver at cheaper pricing.
Avid Rabid Hobbyist
The following users thanked this post: egonotto, Martin72
Offline 2N3055
  • Country: hr
« Reply #91 on: November 06, 2023, 10:41:03 pm »
That is not even the biggest thing. Take a look at ever expanding suite of Analysis and Compliance test packages. That is what so far was exclusive to big brands.  High end scopes are not only about big BW. It is about analysis packages and capability.
And there is the big leap happening..
The following users thanked this post: egonotto, luudee
« Reply #92 on: November 06, 2023, 10:44:24 pm »
Yes, I picked all options out yesterday from new pricelist:
SDS7000A-FG
SDS7000A-16LA
SDS7000A-PA
SDS7000A-EJ                   Eye Diagram/Jitter analysis
SDS7000A- I2S
SDS7000A-1553B
SDS7000A- FlexRay
SDS7000A-CANFD
SDS7000A-SENT
SDS7000A-ARINC
SDS7000A-Manch
SDS7000A-USB2
SDS7000A-CT-USB2              USB Compliance test
SDS7000A-CT-100Base-T           100Base-TX compliance test
SDS7000A-CT-1000Base-T
SDS7000A-CT-100Base-T1
SDS7000A-CT-1000Base-T1
SDS7000A-1GPTS                1 Gpts mem depth
Avid Rabid Hobbyist
The following users thanked this post: luudee
Offline Martin72
« Reply #93 on: November 06, 2023, 10:49:47 pm »
Except the memdepth, this is appx on lecroy-level, nice.
Offline luudee
  • Country: th
« Reply #94 on: November 07, 2023, 03:29:53 am »
@Rob,
do you know if SDS7000A-1GPTS  is a SW only upgrade, or includes HW as well ?
Thank you !
Best Regards,
rudi
« Reply #95 on: November 07, 2023, 03:44:37 am »
SW option. Not cheap.  :(
Avid Rabid Hobbyist
« Reply #96 on: November 07, 2023, 07:19:52 am »
OP updated with English datasheet and better image.
Avid Rabid Hobbyist
Offline Martin72
« Reply #97 on: November 14, 2023, 06:38:35 pm »
I noticed it earlier on the Batronix site by complete coincidence:
So you don't see anything when you go to the page with the Siglent products, but if you happen to stop with the mouse pointer and a dropdown tab opens.... 8)
The following users thanked this post: ddrl46
« Reply #98 on: November 14, 2023, 07:49:30 pm »
Avid Rabid Hobbyist
« Reply #99 on: November 15, 2023, 02:11:23 am »
Released today and links added to the OP.
Avid Rabid Hobbyist
The following users thanked this post: KungFuJosh, Martin72, luudee, Ulrich.G
