Author Topic: Siglent SDS800 series averaging- not?  (Read 492 times)
Online Conrad HoffmanTopic starter
    • The Messy Basement
« on: December 04, 2024, 02:09:40 pm »
Even our bottom-of-the-line Tek scopes at work have trace averaging. I vaguely remember a range of 2-64 or similar. This can be handy for suppressing noise. The noise averages to near zero, while the signal builds up, assuming you have a solid trigger for the signal. I don't see anything like this on my Siglent. Just not an available feature? Maybe someday in a firmware upgrade? Or am I not looking in the right place?
Offline tautech
Re: Siglent SDS800 series averaging- not?
« Reply #1 on: December 04, 2024, 02:13:18 pm »
Averaging is a Math operation, you'll find it in the Math menu.  ;)
The following users thanked this post: Conrad Hoffman
Online mawyatt
« Reply #2 on: December 04, 2024, 02:15:30 pm »
You'll find this in the Math Functions where you can set the Average Source, Number and Scale Factor.
Wonderful little DSOs these SDS800 HDs, hard to believe the performance and features for the $.
You made a great choice :-+
Edit: See Rob beat me to it ;)
You can even do the Average of another Math function by section of the Math Function as the Source for the Average, like the Average of the C1 Squared or the Average of C1*C2 (Handy for Power Measurements).
Here's an example of the Average of C1*C1 of a complex waveform captured by C1.
Best
« Last Edit: December 04, 2024, 03:12:34 pm by mawyatt »
~Wyatt Labs by Mike~
Online 2N3055
  • Country: hr
« Reply #3 on: December 04, 2024, 02:58:27 pm »
You can also create complex math formulas in single math channel - it has formula editor.
Dr. Richard W. Hamming
« Reply #4 on: December 04, 2024, 04:31:09 pm »
Thanks! I kept thinking it would be under Acquire.
Online 2N3055
  • Country: hr
« Reply #5 on: December 04, 2024, 04:53:22 pm »
And that would not be wrong thinking.
Upper models do have additional acquisition modes ERES (Hires of a sort) and  Average as acquisition mode, in addition to have it as a math mode.
Advantage is it is a bit faster, but if you use it as acquisition mode, then it applies to all channels and you have no original waveform.
When you apply ERES or Average as math, you can it individually on each channel, and you have original data too.
So even when scope is stopped, you can, for instance, change ERES parameters post stop to tune in best result.
In practice, I use ERES and Average as math channel most of the time, even on scopes that support it as acquisition mode, because of those reasons.
The following users thanked this post: Performa01, Someone, KungFuJosh
Online mawyatt
« Reply #6 on: December 04, 2024, 05:14:55 pm »
Yes the Formula Editor is a very powerful feature that seems to be often overlooked. With a modern AWG one can create all sorts of interesting results with the various waveforms available from the AWG and all the mathematical manipulations from the Formula Editor. This goes far beyond the common FFT that most DSOs have today, altho the SDS800X HD has really nice useful FFT, not just a toy implementation.
It's fun to actually "see" waveforms in real time of complex mathematical functions/formulas and such rather than on a computer screen as an uninspiring graph. Similar in fashion to having a circuit simulation and actually building such, and making physical measurements.
Best
« Last Edit: December 04, 2024, 05:49:53 pm by mawyatt »
The following users thanked this post: Performa01, 2N3055
Offline tautech
« Reply #7 on: December 04, 2024, 10:09:18 pm »
As was traditional.
But then all channels get averaging applied.
800X HD has 4 Math channels that can be applied including Math on Math.
But things get crowded quickly but we have the ability to Hide any channel so to only have the remaining ones we need.
We can also set our measurements to any of the Math channels.
Much info on their capabilities can be found in this thread:
https://www.eevblog.com/forum/testgear/sds800x-hd-review-demonstration-thread/
Have fun exploring these powerful little DSO's.  :)
« Reply #8 on: December 05, 2024, 01:25:53 am »
Have played with the averaging- like it better than the Teks!
