Author Topic: Siglent sds804x bodeplot using Rigol dg1022z  (Read 398 times)
Offline jomosoftTopic starter
« on: December 20, 2024, 08:13:56 am »
It's time for a new dso and I'm going to choose between Rigol ans Siglent. I own a Rigol dg1022z awg. Would it be possible to use that for bode plots with the Siglent dsd804x ?
Offline das_strobel
Re: Siglent sds804x bodeplot using Rigol dg1022z
« Reply #1 on: December 20, 2024, 01:47:37 pm »
This works very well for me (except that I have the SDS1000X HD). See this thread: https://www.eevblog.com/forum/testgear/siglent-sds1104x-e-and-sds1204x-e-bode-plot-with-non-siglent-awg/
« Reply #2 on: December 20, 2024, 04:04:18 pm »
Thanks for the link, which driver do you use ?
Offline das_strobel
« Reply #3 on: December 21, 2024, 06:12:58 am »
I use the the dg800 driver. See the README from this repo https://github.com/hb020/sds1004x_bode. It has a lot of useful hints and tips. I run the python script under Ubuntu Linux normally. But it should also work under Windows and MacOS if everything is installed correctly.
« Reply #4 on: December 21, 2024, 12:30:02 pm »
Thank you so much ! I’m definitely going for the siglent !
