I recently purchased a Siglent SHS806 oscilliscope.
I m trying to record the captured waveform and extracting data via usb.
However, the data value extracted via USB is does not tally with what was shown on the oscilloscope.
I m reading a data from the power supply, measuring 0v-15v.
The oscilloscope is reading 0v -15v correctly.
I plotted the graph via the CSV file
But the data recorded to the usb is not in Voltage, 0v-15v (see attached picture Y-Axis), but in some random values (i assuming is in either bits/byte, but unable to determine the conversion).
I did see other user getting the data that corresponding to the oscilloscope reading (e.g showing 0v-15v on the data), but it did not post a way/guide to setup the reading on the axis.
My oscilloscope firmware is 5.09.01.05
Is there some settings that i need to adjust, so that whatever the oscilloscope detected corresponds to the data recorded values, especially on the Y-axis value, as I have been struggling for a few days already.?
