New firmware for SNA5000A models
except SNA5022A&SNA5032A
V1.0.0.2.16
https://siglent.oss-cn-shenzhen.aliyuncs.com/English_content/Firmware/Vector%20Network%20Analyzer/SNA5000A%20Firmware_V1.0.0.2.16_EN.zip~85MB
Release NotesFeatures and Enhancements:
1. Added GCX measurement mode.
2. Added harmonic analysis measurement function in SA measurement mode.
3. Added full-channel calibration function.
4. Added calibration information display function.
5. Added power compensation function for fixture simulation.
6. Added ECal (Electronic Calibration) characterization function.
7. Added Compression Point Search / Saturation Point Search / Normal Operating Point Search functions.
8. Added Preferences settings.
9. Mixer Measurement Mode: Now supports dual LO (Local Oscillator) function.
10. TDR Measurement Mode: Now supports extended port function.
11. GC Measurement Mode: Now supports extended port function.
12. AFR (Automatic Fixture Removal): Now supports time domain trace display.
13. Minimum Sweep Points: Now supports a minimum setting of 1 point.
14. File Manager: Added support for "Favorites" and "History" functions.
15. Power Meter: Added support for IP connection.
16. Power Meter Reading: Default frequency changed to 50MHz.
17. Switch Matrix: Added support for characterization and de-embedding functions.
Bug Fixes:
1. Fixed the issue where single-ended measurements (e.g., Sss11) would not sweep under balanced measurement mode.
2. Fixed the issue where smoothing results were abnormal under the Phase format.
3. Fixed the issue where traces might appear abnormal after executing a calibration data overwrite.
4. Fixed the issue where the power calibration progress bar might display incorrectly.
5. Fixed the issue where trace data became abnormal after recalling CSV files saved from Power Sweeps or CW Sweeps.
6. Fixed the issue where the sweep would hang when the external trigger signal frequency was high in "Point Trigger" mode.
7. Fixed the issue where the log display time might be incorrect.
8. Fixed abnormal UI control behavior in the SA measurement mode configuration dialog.
9. Fixed the issue where eye diagram data might be abnormal after modifying the rise time in TDR measurement mode.
