Products => Test Equipment => Topic started by: Roger Need on March 06, 2023, 12:44:20 am
Title: Siglent SPD3303C Review and Questions
Post by: Roger Need on March 06, 2023, 12:44:20 am
I just received a Siglent SPD3303C linear power supply that I ordered on Amazon.  Tested it with various loads yesterday and pleased with performance.  It met all specs and observed the folllowing:
Rotary encoder knob has pushbutton capability but it does not appear to be used according to manual.    Anyone found out how to use the pushbutton feature?   If I push it in and power on only the digit 5 appears on the display.  I wonder what that does?
My unit was older stock with a cal date of June 2022 and latest firmware for Version 1.
From firmware release notes a Version 2 of the hardware was released in September 2022.
Does anyone know what the changes are in V2 and if it affects performance or user options?  I still have 30 days to return if V2 is a better product.
Thanks - Roger
Title: Re: Siglent SPD3303C Review and Questions
Post by: abeyer on March 06, 2023, 01:32:40 am
I'm pretty sure that's how you turn it up to 11.
Post by: tautech on March 06, 2023, 02:02:40 am
AFAIK this HW revision is just part of normal HW development/improvement as is SPD3303X/X-E had a similar HW upgrade recently too.
I suspect the 2 are related however Siglent does not share the details of HW changes only flagging them in firmware versions if SW need be changed to support the changes.
If there are changes a user might notice, they are reflected in datasheets and user manuals.
Post by: 7thSenpai on December 27, 2023, 05:20:37 pm
Only thing I found the push button does is resets the overload condition. That is when the led display reads O.L.
