Author Topic: Siglent SPS5000X PSU's  (Read 8068 times)
Offline rf-loop
  • Country: cn
Re: Siglent SPS5000X PSU's
« Reply #25 on: June 30, 2021, 02:02:43 pm »
List prices VAT 0 in EU area
As far as I know, there is also promotional offer:  30.6.2021 - 30.9.2021  10% discount from these list prices below.
Prices are VAT 0%.
SPS5041X   40V/30A/360W,,,,,,,,€   839.00
SPS5042X   40V/60A/720W,,,,,,,,€ 1,029.00
SPS5043X   40V/90A/1080W,,,,,,,€ 1,339.00
SPS5044X   40V/30A/360W*2,,,,,,€ 1,579.00
SPS5045X   40V/30A/360W*3,,,,,,€ 1,879.00
SPS5051X   50V/10A/180W,,,,,,,,€   769.00
SPS5081X   80V/15A/360W,,,,,,,,€   999.00
SPS5082X   80V/30A/720W,,,,,,,,€ 1,239.00
SPS5083X   80V/45A/1080W,,,,,,,€ 1,619.00
SPS5084X   80V/15A/360W*2,,,,,,€ 1,739.00
SPS5085X   80V/15A/360W*3,,,,,,€ 2,089.00
SPS5161X   160V/7.5A/360W,,,,,,€   999.00
SPS5162X   160V/15A/720W,,,,,,,€ 1,239.00
SPS5163X   160V/22.5A/1080W,,,,€ 1,619.00
SPS5164X   160V/7.5A/360W*2,,,,€ 1,739.00
SPS5165X   160V/7.5A/360W*3,,,,€ 2,089.00
There can connect up to 3 parallel and get up to 270A  OR there can connect 2 serial and get up to 320V.
« Last Edit: July 02, 2021, 03:33:15 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
Offline dakiller
« Reply #26 on: July 01, 2021, 11:46:52 pm »
Anyone know the best place in Australia to get one of these?
Offline tautechTopic starter
« Reply #27 on: July 02, 2021, 01:37:38 am »
IPD should have them before we do however as they have just been released it might be a few weeks before any of us have stock.
https://int.siglent.com/map/
Offline Incircuit
« Reply #28 on: July 02, 2021, 02:28:25 pm »
Has anyone tried the devices yet? Consider buying a SPS5083X.
« Reply #29 on: July 02, 2021, 09:30:33 pm »
Welcome to the forum.
Bit early for anyone to have these yet as officially they have only been released a few days and a European beta tester I know has only had his for a few weeks.
I'm getting a 60A one to play with but it's some weeks away yet.  :(
Online 2N3055
  • Country: hr
« Reply #30 on: July 02, 2021, 11:29:18 pm »
Could you be more specific about your needs and expected use cases, please?
There are many things that are known: these are switchers, they have adaptive power envelope (more current at lover voltages), they are generally meant for ATE and that type of use (most of them have fixed output posts on the back, also needed for currents in question), they are very compact for the power they provide. They can be used in lab for general use, but front panel is not optimized for that kind of work (not numeric keypad and such). They also have (in addition to standard SCPI control and web server control) an old school voltage /resistance voltage/current and on/off control and monitoring of channels. They also support sequence programming.  They seem to have serious thermal design, made for continuous work under full load, mounted in rack.
There are many interesting features: choice of priority of CV or CI control loop, slew rate strategy and channel control, selectable downprogrammer, channel sequencing, several protection circuits.
They can also control output resistance of voltage source.
They seem quite interesting.. There are no manuals published yet, but as soon as they are, there will be much more details there.
Dr. Richard W. Hamming
Offline rf-loop
  • Country: cn
« Reply #31 on: July 03, 2021, 03:33:01 am »
Same manuals are also public available from Siglent domestic web sides but only with chinese language.
Because product is officially published for purchase, also these must be public. (Who buy a pig packed in a sack)
Preliminary User Manual
( reason for my previous cancel was: this is some kind of preliminary, look pages 86, 87 chinese text in some setup images. Also not officially published at this time so careful with possible errors )
Data sheet
SPS5000X Manuals and data sheets etc can also find here. (Siglent global main sides)
« Last Edit: July 06, 2021, 01:09:20 pm by rf-loop »
Offline Incircuit
« Reply #32 on: July 05, 2021, 02:07:55 pm »
Thanks for the replies. I think I'll wait a bit until the devices are fully tested.
I found the user manual here.
Offline tv84
  • Country: pt
« Reply #33 on: August 18, 2021, 09:11:52 pm »
1st FW release.
Product_ID: 800
« Reply #34 on: August 25, 2021, 10:11:14 am »
1st FW release.
Product_ID: 800
But not what my SPS5042X arrived with....now updated.
First impression is how small the front panel is at just some 140mm (5 1/2") square yet they are quite long ~400mm (16").
The twin smart fans could run a touch slower when output = OFF and this has been requested as an improvement.
Now to make some 60A leads......
Online 2N3055
  • Country: hr
« Reply #35 on: August 25, 2021, 11:55:19 am »
1st FW release.
Product_ID: 800
You do realize we expect to see photos of welding with an electrode....
60 amps should be enough for thin ones...
 :-DD
The following users thanked this post: tv84
« Reply #36 on: July 25, 2022, 01:32:32 am »
New firmware for SPS5000X models.
Version V3.1.1.8
https://int.siglent.com/upload_file/zip/firmware/Power_Supply/SPS5000X_V3.1.1.8_EN.zip
512KB
Release notes
1. Change some user interfaces and operation methods
2. SET button changes to V/I function in main windows.
3. Optimized some features in list’s setup/save/web menus
« Reply #37 on: November 22, 2022, 09:42:57 am »
Defpom has a quick look at our SPS5042X.
