Output voltage, current rising/decrease slope can be adjusted
The SPS6000X power supply supports custom setting voltage/ current increase/ decrease slope, which can verify the performance of the object to be measured during the voltage/ current change process. The voltage rising decreased slope range is 0.001 ~ 4V/ms, and the rising decreased slope range of the current is 0.001 ~ 0.5A/ms. This function can effectively avoid the damage of the DUT in a special application case, such as the test of a strong current absorption device like a capacitor. Reduce the harm of the surrounding current to the measured load.
Efficient and convenient remote control
SPS6000X has USB, LAN communication interface, and optional USB-GPIB modules. Through the embedded Web Server function, you can remotely control the instrument through the browser without installing complicated driver software and upper machine software, which can easily meet the application needs of special environments such as high pressure and high temperature.
Users can also save various types of files into inner and outer memory, and read and call them when needed.
