The official Brymen silicone leads are only about $10USD.
But they don't cost these money, it seems that defective probes with high or floating resistance is a common issue of Brymen brand...
My Brymen probes had such issue just out of the box, and at least 2 people from this thread also reported the same issue.
As I said before, I wrote them email about that issue and they respond that this issue is normal for their production, because they don't using soldering "For reliability, our test lead design uses mechanical grab" and "You may use Relative feature to offset it."...
They propose to use Relative feature because their probes have floating resistance from 0.08 to 1-2 Ω...
That's all what you needs to know about Brymen probes...
