Author Topic: Siglent SSA5000A 13.6 & 26.5 GHz Spectrum Analyzers  (Read 3531 times)
Offline tautechTopic starter
« on: April 10, 2021, 12:11:13 am »
New Siglent Analyzer models of 13.6 and 26.5 GHz.
SA Models
SSA5083A   9 kHz ~ 13.6 GHz
$18,010
SSA5085A   9 kHz ~ 26.5 GHz
$20,880
RBW 1 Hz ~ 10 MHz; DANL -165 dBm/Hz; SSB <-105 dBc/Hz; RTSA BW up to 40 MHz(option)
Options
SSA5000-F5   SSA5083A upgrade to SSA5085A (software license)
SSA5000-B40   40 MHz analysis bandwidth (software license)
SSA5000-RTA1   Real-Time Spectrum Analysis (software license)
SSA5000-AMK   Advanced Measurement Kit (software license)
SSA5000-AMA   Analog Modulation Analysis: AM, FM, PM (software license)
SSA5000-DMA   Digital Modulation Analysis: ASK, FSK, MSK, PSK, QAM (software license)
SSA5000-P3   Pre-amplifier, 9 kHz ~ 13.6 GHz (software license)
SSA5000-P5   Pre-amplifier, 9 kHz ~ 26.5 GHz (software license)
SSA5000-EMI   EMI measurement mode (software license)
Option price indication $ 850 - 3800 ea
Real-time spectrum view Probability density spectrum, waterfall chart, 3D spectrum, time power spectrum
Advanced measurement functions (optional) CHP, ACPR, OBW, CNR, Harmonic, TOI, Monitor
Model modulation analysis (optional) AM, FM, ASK, FSK, MSK, PSK, QAM
Remote control interface LAN, USB Device, USB Host (USB-GPIB)
Remote control capability SCPI/Labview/IVI based on USB-TMC/VXI-11/Socket/Telnet/I-MAX, Web Browser, Easy Spectrum software, File Explorer
Display 12.1 inch (1280x800) display, support mouse and keyboard
English datasheet:
https://int.siglent.com/u_file/download/22_09_22/SSA5000A_DataSheet_EN_01A.pdf
Released 26 Sept 2022
4 weeks current lead time.
Release promotional offer:
SSA5000-P3 and SSA5000-P5 function will be free from orders between September 26th to December 31st.
https://int.siglent.com/products-overview/ssa5000a/
https://siglentna.com/spectrum-analyzers/ssa5000a-series-spectrum-analyzer/
https://www.siglenteu.com/spectrum-analyzers/ssa5000a-series-spectrum-analyzer/
« Last Edit: September 26, 2022, 08:07:18 pm by tautech »
The following users thanked this post: egonotto, Bravo
Re: Siglent SSA5000A 13.6 & 26.5 GHz Spectrum Analyzers coming
« Reply #1 on: April 12, 2021, 07:42:26 am »
This will apparently be on show at Electronica in Shanghai this week.
https://www.electronica-china.com/en/
SIGLENT TECHNOLOGIES CO., LTD.
Stand N4.4275
« Reply #3 on: September 14, 2022, 09:34:43 am »
Western release is in just under a fortnight and a 26.5 GHz SA for under $25 k is very impressive.
As expected the new SSG5000A RF gen is to be the TG source when coupled with SSA5000A models which for both there will be 13.6 and 26.5 GHz versions.
More later.....
« Last Edit: September 14, 2022, 09:38:45 am by tautech »
Offline switchabl
« Reply #4 on: September 14, 2022, 10:45:43 am »
I think at current exchange rates $25k might almost buy you a Rohde & Schwarz FPL. Maybe more of a gap once you add options to both. I still like the form-factor of the new 5000 series.
« Reply #5 on: September 26, 2022, 06:32:09 am »
Western marketplace release is today, 26th Sept.
OP updated.
Expect further edits as more info becomes available.
« Reply #6 on: September 26, 2022, 09:42:30 pm »
BTW
SSA5000-P3 and SSA5000-P5 function will be free from orders between September 26th to December 31st 2022.
Offline hpw
« Reply #7 on: September 27, 2022, 10:59:30 am »
A good test would be:
- Input of an OXCO as 10/100MHz
- Set RBW to 1Hz
- have center as given signal
- Freq. range as +/- 100 or 200Hz
and look at the side peaks as they alter ...  :o, as nice to see on SSA3000A Plus series
Offline Scratch.HTF
« Reply #8 on: September 29, 2022, 12:18:14 am »
Gross margins for an illegally upgraded SSA5083A can be north of 55% - the hardware-related options requiring a software key are particularly lucurative.
If it runs on Linux, there is some hackability in it.
« Reply #9 on: November 25, 2023, 09:32:54 am »
New firmware for SSA5000A models.
Version: 1.1.2.1.7R3
72 MB
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SSA5000A_1.1.2.1.7R3_EN.zip
Release notes.
Support EMI mode
VNC interface optimization
Solved Issues:
The default detection type of the third-order intermodulation in SA mode is changed to Pos
Fixed cursor readout update error when the readout type is not auto
10dB higher signal amplitude under harmonic analysis
Harmonic analysis cannot modify the number of harmonics
Solved the problem that FTP cannot be used
MA mode time domain graph marker display unit corrected to dBV
