Author Topic: Siglent SSG3000X and SSG5000X series RF Signal generators  (Read 20520 times)
Online coromonadalix
Re: Siglent SSG3000X and SSG5000X series RF Signal generators
« Reply #75 on: March 31, 2023, 03:51:58 pm »
Reworked some buttons sizes
« Last Edit: April 13, 2023, 11:52:45 am by coromonadalix »
« Reply #76 on: April 13, 2023, 02:36:35 pm »
oh  received questions
the original  siglent labview files : SSG-X-series-Labview-Driver-V2.0.zip     available at their instrument download ...
the zipped   VI  My Project file put there : SSG-X-series-Labview-Driver-V2.0\Public\Configure
OR The one who contain everything : SSG-X-series-Labview-Driver-V2.0 - 1.zip
You launch : Siglent SSG Series.lvproj   and open the VI   I created
lots of thing to learn and very old tutorials on the web  :--
« Last Edit: April 18, 2023, 10:43:36 am by coromonadalix »
Offline Detlev
« Reply #77 on: April 13, 2023, 04:20:54 pm »
It's pretty quiet around the SSG5000X here. What is your experience with the SSG? Is it recommended? The so-called A-brands are clearly more expensive than the Siglent
This post is "Made in Germany" 😎
« Reply #78 on: April 13, 2023, 08:36:55 pm »
Its good for the use i have at my job,  to go into the very low db outputs,   -110 db
I use it for very short pulse generation
Hacked  loll to 3.2 gig output,  but does not have the IQ option board
I wold say works pretty well,  but clumsy touch screen interface in some ways / too small loll .... thats why i tried to build an NI Labview interface, since i play a lot with output levels, the joggle encoder wont survive long
Does the job ... and saved $$$  since hacked  loll
For sure its a big unit,  and may not please audience
But if an Labview expert is lurking around  loll   PM me
I have a hard time to figure out a few things and or add the AM / FM  options  etc ...   and compile it to an full executable, i dont know if i can get rid of the  NI Labview frontpanel  or have the front panel RUN arrow integrated in the software GUI ???
« Last Edit: April 14, 2023, 03:46:10 am by coromonadalix »
The following users thanked this post: Detlev
Online tautechTopic starter
« Reply #79 on: October 12, 2023, 07:04:49 pm »
New firmware for SSG3000X models
Version´╝Ü V1.0.3.1.21
32 MB
https://int.siglent.com/upload_file/zip/firmware/Radio_Frequency_Signal_Source/SSG3000X_V1.0.3.1.21_EN.zip
Release notes
1. Fixed the defects related to the flatness list function
2.Fixed the defects related to SCPI command
3. Fixed the defects related to the VNC function.
The following users thanked this post: egonotto, james38
Offline james38
« Reply #80 on: October 13, 2023, 11:32:14 pm »
Update successful without issues so far.
Regards Chris
« Reply #81 on: May 23, 2024, 03:04:02 pm »
hi @all
tried to "hack" a new ssg3021x  received yesterday, and alas  i did not took notes on this one, i can not make it work again  |O |O :palm:
here's is the main.py  i've tried,   with an added 30M, 2100M, 3200M,  and 21BW32 option(s)  not sure if they placed at the right option lines  ....
tried with the sn only, or both  sn and scopeid ... no avail
MCBD?    reports nothing on theses models
MD5_SRLN? and  MD5_PR?   works fine
HELP ?
« Last Edit: May 24, 2024, 11:09:00 am by coromonadalix »
Offline tv84
  • Country: pt
« Reply #82 on: May 23, 2024, 06:17:14 pm »
"SSG3000X", "3200", "TRAI", "INQU", "POWE", "PULS"
« Reply #83 on: May 24, 2024, 12:22:00 am »
oh  damn  never tought of theses, or never knew, can't even recall i used this ???  or you where the helper TV84
Since MCBD?   request are not working
Is there other ways thru scpi  to request installed licenses, to do a cross check  like other instruments ??
ill answer tomorrow  for the BW upgrade
thks once again
« Last Edit: May 24, 2024, 04:48:31 pm by coromonadalix »
« Reply #84 on: May 24, 2024, 10:47:43 am »
not working ....    '3200'  or '3200M'   'MAX'     this one is resisting all attempts
edited python script to reflect what i've tried
empty SCOPEID or the same as SN,  nothing worked
« Last Edit: May 24, 2024, 11:39:00 am by coromonadalix »
« Reply #85 on: May 24, 2024, 04:57:30 pm »
ok  for the scripts
lots of conflicting infos
SCOPE ID / HOST ID     scripts versions    etc ....  capital or lowercase  entries  etc ...  there is a few floating around the web
here's the one ive found with lots of comments in it, and i added some of my comments,  who worked for me (attached)   some say try the SSA script  ....  it does not work for me, numbers doesn't fit,  i'll retry them later
IT IS A SCOPE SCRIPT ??? or i mess things up again  loll
checked with a few equipment's i had noted their " before and after "   ... but not on 1st SSG3000X  |O |O  and i received help for it.
FOR THE SSG3000X  series  do note,   now i have 2x of them BW upgraded,  they don't respond to MCBD?  commands  and not  MCBD xxxxxxx  when you try to enter unlock numbers, i had to do it thru the front panel.
hope it help a few here, because infos are getting so diluted between threads ... and i'm not god  loll
i have to thank some people here  :-+
o it
« Last Edit: May 28, 2024, 03:23:26 pm by coromonadalix »
« Reply #86 on: May 28, 2024, 03:37:34 pm »
updated
The 'WIFI' is found at 2 places,  not sure witch is right or wrong,  take this with a grain of salt
added some text
« Reply #87 on: June 03, 2024, 06:40:54 pm »
reworked other buttons sizes     ....  totally forgot how to ...  |O  :palm:
you need NI runtime engine ....
« Last Edit: June 03, 2024, 06:43:16 pm by coromonadalix »
