Author Topic: Siglent SSG5000A 13.6 and 20 GHz RF Sig Gens  (Read 1612 times)
Offline tautechTopic starter
« on: April 12, 2021, 02:52:57 pm »
SSG5083A 13.6 GHz
SSG5085A 20 GHz.
Release 26 Sept 2022
SSG5083A   9 k ~ 13.6 GHz
$16,210
SSG5085A   9 k ~ 20 GHz
$19,070
Options
SSG5080A-PU   Pulse modulation (software license)
SSG5080A-PT   Pulse train generator (software license)
SSG5080A-LP   110dB Attenuator module (hardware, assembled and calibrated in factory only)
Level setting range: -130 dBm ~ +25 dBm
Output frequency resolution up to 0.1 Hz
Phase noise <-120 dBc/Hz@1 GHz, offset 20 kHz (typical value)
Amplitude accuracy ≤0.7 dB (typical value)
Support AM/FM/PM analog modulation, support internal and external modulation methods
Support pulse modulation function (optional), pulse train generator, user-defined pulse sequence (optional)
Power meter control kit for and line loss correction
Supports web remote control
5-inch capacitive touch screen
Rich communication interface: standard USB-HOST, USB DEVICE (USB-TMC), LAN (VXI-11, Socket, Telnet), optional GPIB
English datasheet:
https://int.siglent.com/u_file/download/22_09_23/SSG5000A_Datasheet_DS0805A_EN02B.pdf
https://int.siglent.com/products-overview/ssg5000a/
https://siglentna.com/rf-generators/ssg5000a-series-rf-signal-generator/
https://www.siglenteu.com/rf-generators/ssg5000a-series-rf-signal-generator/
« Last Edit: September 26, 2022, 08:54:52 am by tautech »
The following users thanked this post: egonotto, Bravo
Re: Siglent SSG5000A 13.6 and 20 GHz RF Sig Gens coming
« Reply #1 on: September 26, 2022, 08:54:34 am »
Released today to coincide with the release of the new Siglent SSA5000A analyzers.
OP updated with links, pricing and specs.
Online graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #2 on: September 26, 2022, 08:28:48 pm »
The +25 dBm output is impressive at that price.
Offline switchabl
« Reply #3 on: September 26, 2022, 09:15:05 pm »
That's just the setting range though, the actual max. output power depends on the frequency (13/15 dBm @ 20 GHz with/without mechanical step attenuator option).
