Hello all,
I have a friend that owns a Siglent SVA1015X that present a bizarre behavior... Please, have a look at the picture below. The connection is a simple coax cable (50 Ohm), from PORT1 to PORT2. Then the TG function is activated and the result is as shown on the picture. The frequencies where the slopes appear are always the same. The difference in magnitude is about 4dB.
I would appreciate very much any comment about what could be wrong with this equipment (or its operator).
Thank you all for your time.
Best regards,
Emmanuel.
" alt="" class="bbc_img" />
