Hi, it's actually a pretty advanced instrument with very high quality output, with ultra-low jitter, and isolated from ground (sure, one could use a transformer, but that has it's own limitations). These things are rare to see in a lot of AWGs. It's hard to get much better at that price perhaps. I think it's still Tek's top-end model for that reason.
AFG31000 is a good instrument. I will repeat this again in case you missed it first time.
But 80 Mhz AFG31000 competes with 500€ Rigols and Siglents in general capability it offers to a user..
In which case, only thing that instrument has going for it is isolated output and big screen. Everything else is just slightly better or similar.
And your repeated insinuations about quality of "non expensive" equipment is your prejudice. You are putting into same basket noname Aliexpress toys and SDG7000A or SDG6000X ?
That is both ignorant and insulting.
What "unknown 350MHz scopes.."?
I know, at least for Siglent, that their scopes are excellent, very known quantity and quality and being sold as LeCroy.
To quote you, "I personally cannot quantify what end application I cannot develop with this.. " SDG6000x that you can with 80 Mhz AFG31000, but I sure can make you a list of stuff you cannot do with 80 Mhz AFG31000 that I can with SDG6000X.
And yes, 500MHz AWG is better than 80 Mhz AWG. Few days ago a person here took this SDG6000X, created PAL test signal, and modulated it to RF TV channel.
All in one instrument.
SDG6000X also supports I/Q modulation. Double pulse testing, sequencing.
And it has clean signal with low distortion. Specifications are very conservative and distortion is much lower that stated.
I measured jitter down to 2-3 ps RMS where my capability to measure it ran out. I have no idea why in specifications they state 100ps (worst case, not typical, by the way) because I have yet to find that spot.
All in a very compact instrument.
So yes, you get a lot for your money.
In fact, you can get good scope, good AWG, good multimeter, and good PSU for the money that they ask for AFG31000 .
And with that combination, there is a LOT of things you can do, that you cannot do with AFG31000 alone.
But if I remember correctly, you are the person that comes in Siglent SD800xHD and Rigol DHO800 topics and profess that you don't understand why people would buy "these Chinese toys" when they can buy something like R&S MXO4 "which is better scope, you know".
So I don't expect you to understand.
