Author Topic: Signal Hound SM435C 43.5GHz Real-Time Spectrum Analyzer Review, Teardown & Exp.  (Read 911 times)
Online HugoneusTopic starter
    • The Signal Path Video Blog
In this episode Shahriar reviews the successor to the popular Signal-Hound SM200C, the SM435C Real-Time Spectrum Analyzer covering 100kHz – 43.5GHz with 160MHz of gapless I/Q steaming using a 10GbE optical interface.
https://signalhound.com/products/sm435c-43-5-ghz-real-time-spectrum-analyzer-with-10gbe/
With its constantly improving Spike software and incredible 1THz/s sweep rate, the SM435C has the potential to be a dream software-defined radio as well as a powerful laboratory & field instrument. This detailed review is organized as follows:
00:00 – Introduction
01:47 – Instrument overview & design
03:49 – Teardown, detailed circuits & systems overview and analysis including X-Ray imaging
16:33 – Analysis of a 24GHz pulsed radar module, real-time capability, zero-span mode, fast sweeps
29:06 – Noise figure personality and noise-figure measurements features
33:40 – Phase noise personality and characterizing the internal instrument phase-noise
33:49 – mm-Wave transmit mixer characteristics, digital demodulation capabilities
39:05 – Wideband IF output for digital demodulation using a Keysight MXR & PathWave VSA
41:35 – Wideband IF output for rapid pulse hopping analysis using a Tektronix MSO-6B Series
45:06 – Additional Spike software features
46:11 – Concluding remarks
You can watch the video here: [47 Minutes]
https://youtu.be/af2HJjrmb0I
The following users thanked this post: KeBeNe, trophosphere, TheSteve, slothsd, Kosmic, mankan, TomWinTejas, Detlev
Offline coromonadalix
Thank you for your videos / explanations   :-+
An 10gbe  lan,  mani it must spit  tons and tons of data  if you do a full coverage ... and the speed it does ....
