Three answers before i leave for the mountains
@HighVoltage, you are corect, Aftermarket Automotive. The new scope will be used to reverse engineer parts and sensors and of course for new hardware development. to probe inside a car we will probably still use the Tek TPS a lot (battery operated, more forgiving inputs, believe it or not the best we have to look at slow signals, i LOVE scan mode. Not so much a fan of Roll)
The boards we make are not particulary high speed, due to low power contstraints, the only "high speed" part is SPI communication intra-board.. so high bandwidth scopes and probably most of lecroy's wave analysis tools would be kind of wasted with us.
First considerations: i wish, i really really wish that they both made lower bandwidth versions of these scopes: I'd be fine with 50/70 MHz, if i really need to look at higher speed signals integrity i can bring a boat anchor from home for a few days.
Too bad scope manufacturers still thinks like this: you want unusual protocols? you want histograms, waveform analysis? you must do high speed.
Unusual protocol we need: SENT.
The standard suggests 5-6 MICROSECONDS rise and fall times to contain EMI (but i've seen real world implementations with straight edges, eh.)
it is fairly slow.
Lecroy offers SENT trigger and decoding starting from the (discontinued) WS Mx44-S, 400 MHz, or the (in production) HDO4000, 200 MHz, which starts at about 10k list price in 4 channels. No need for the bandwidth and a price class that cannot be justified by us. 200 MHz to see a protocol that takes milliseconds to transmit a frame.. (end of rant)
i know, unusual means that if you need, you need to pay.. but Keysight offer this in option starting from the 3000T series and that has been a blessing.
Also, picoscopes have it available from the crappiest 2000 series, and we used that before.. but it has its drawbacks, such as inability to trigger from errors.
I had to trace an error in a device, the car wasn't happy with it. turns out, there was a sporadic error in the slow channel (hundreds of milliseconds to transmit). With the picoscope i would have never been sure to catch it because samplerate would drop to a point that the decode function wasn't guaranteed, with the keysight a quick set up and problem was found.
Could also build a quick and dirty hardware protocol decoder.. but i wasn't sure i could trust it.
Does the decoder always run at full samplerate in the keysight? it would appear so.. with SPI,I2C,SENT and CAN it would either DECODE correctly or not.
By the way, the same for LeCroy. Fantastic decoder, a bit difficult to set up at first, though.
@2N3055: I shall make some screenshots first!
@lem_ix: please, keep in mind that the main processor in the keysight is almost solely for the user interface, the interface in the keysight is always snammy because of it (and i love it). In the lecroy, considering also that it is an older machine (2014 vs 2015 i believe) the controls are not as fluid or snappy, at slower timebases (AND WITH DEEP MEMORY) it will be slower to use: rotate the encoder, the trace starts moving about 300-500 ms later. I believe this scope is to be set up and not touched, is not made for moving things around a lot
