Author Topic: sigrok an Rigol DS1000Z series: good and bad  (Read 902 times)
Offline DiTBhoTopic starter
« on: November 15, 2022, 10:56:44 am »
So, Sigrok seems to have support for the Rigol DS1000Z series, see here.
Unfortunately I don't have a Rigol DSO on hands to verify.
I would like to buy a DS1104Z (100MHz), but only if I can control it from an embedded linux board over ethernet.
I need to dump two channels, as fast as possible.
Feedbacks? Comments?
Offline Fungus
Offline thm_w
  • Non-expert
Re: sigrok an Rigol DS1000Z series: good and bad
« Reply #2 on: November 15, 2022, 10:37:31 pm »
You might want to determine what "as fast as possible" is as a minimum requirement.
It could be multiple seconds to complete over USB: https://www.eevblog.com/forum/testgear/ethernet-transfer-speed-for-rigol-ds2072a-and-ds4014/
If faster data is required, look into picoscope or DScope, etc.
Offline switchabl
« Reply #3 on: November 16, 2022, 12:09:20 am »
I tried PulseView (which is based on Sigrok) with a DS1054Z a few months ago and it was not really usable. The timescale was wrong and changing the memory length didn't work. It is possible that this was a specific problem with my setup or that it has been fixed in the meantime.
But of course, you could just control it directly using SCPI. If you just want to target one specific device using Sigrok is probably not worth it.
