Hi!
I bought a cheapie Digimess DMM200:-
http://uk.farnell.com/digimess/dm200/multimeter-dig-bench-4000-count/dp/1076811 as "sold as seen" and unfortunately I found a problem with the DMM chip, a Japan Radio NJM9210FC, which appears to be jumping at random between ranges and several LCD segments gone!
Can anyone point me in the direction of cheaper models of DMM/clamp meters that use a '9210FC DMM chip please?
I got a set of circuit-diagrams for the Digimess from the seller and I've got the chip datasheet saved and there's good IR desoldering-tackle at work I can use, so it's just a matter of another chip!
Suggestions, anyone, please?
PS!
Is there another type of DMM chip likely to be compatible with the LCD used with the '9210 or would I have to get a new LCD panel to match another DMM chip design - I believe these things are multiplex-drive!
Chris Williams
