My previous post
here was with the 3Hz filter on. These are with the 200Hz filter on and are significantly lower.
Edit: Very uniform 34% +/-1% reduction from the 200Hz filter. The 8846A high med and low resolution modes in AC only change the normal display resolution and do not affect the stat mode resolution or readings at all.
100mV range was 12.48081µ with 3Hz filter
1V range was 106.8218µ with 3Hz filter
10 range was 998.5290µ with 3Hz filter
100V range was 11.89725m with 3Hz filter
1000V range was 110.9135m with 3Hz filter
