First, thank you all for tips and tricks regarding measuring devices!
The situation is as follows: Big bunch of notebooks get handed out to students for doing some exams, are later collected and wiped clean. Then they will get hooked up to an appropriate charger to get the battery re-charged.
So now there are numerous manufacturer-provided mains (230V/EU) power supplies on a power bar, that in turn gets plugged in into the mains- so easily 12 capacitors will really draw some juice.
By my experience (I did similar measurements with a Fluke 435 power quality analyzer at my last employer) in the first 20ms (full wave) the interesting part happens.
Goal: I want to understand how the notebook chargers behave, so I can draw up a simple chart and be like: On a power bar at a given time only XY of those chargers/wall warts, before they get plugged in into mains.
In the workshop, where some guys will charge them, one could also think about using some different circuit breakers- in germany the B characteristic is quite popular, so this could be changed to the K version.
(C is also ok, but K gives you still more resilience against short spikes, and D is no good in EU systems)
Question here: Are nowadays power clamps or multimeters really fast enough to capture the first 20ms reliably? For understandable reasons I do not want to put in a standard DSO as bench version to that- risk of accident or other hiccup in that environment is not worth it...
(For other spikes and longer periods of drawing power, like a big server spinning up its hard drives, we would talk about seconds where a multimeter easily could do with the min/max autohold function, I know)
