No idea on the BW issue.
If the majority use of the system is related to national security, defense or space, then the export is classified under ITAR rules. If it has both a common commercial and defense use, then it is managed under the Commerce Dept "Dual-Use" system, where you (and the gvt) make a case as to the intended use, originator and end-user and the item is either classified as munition related or as commercial use and you apply the appropriate export controls. Then the layers of tariffs, trade sanctions, limits, agents, etc.
Commercial use has always had some diversion into defense and like areas. The classification becomes more complicated in the software defined era when feature sets are already baked waiting to be unlocked or easily soft loadable. Consider software unlockable analyzers, precision machining equipment, processor features.
A problem, in particular, with TE and machine tools, is that almost everything can be dual-use.
If you look at the Wassenaar Arrangement you will be surprised at the range of categories that are listed as dual-use.
Read
About, then
List of Goods if interested:
http://www.wassenaar.org/about-us/Over time, use classifications evolve with technologies and markets. Satellite technology was once classed as a munition, now it is dual use. Processors were classified by capabilities, as exportable or not. Been a long time, they may still be. You would also run into the occasional comedy of not being able to export a item back to the country of origin.
