I have renamed the FPGA bit file and placed it in the correct directory as directed.
Pulseview finds the hardware.
The error message I get is "Failed to open device generic/ unspecified error" but reading the log file give a different story
ssr: hwdriver: Scan found 0 devices (saleae-logic16).
sr: hwdriver: Scan found 0 devices (siglent-sds).
sr: hwdriver: Scan found 0 devices (sysclk-lwla).
sr: hwdriver: Scan found 1 devices (sysclk-sla5032).
sr: hwdriver: Scan found 0 devices (yokogawa-dlm).
sr: hwdriver: Scan found 0 devices (zeroplus-logic-cube).
sr: device: sysclk-sla5032: Opening device instance.
sr: usb: Trying to open USB device 2.17.
sr: usb: Opened USB device (VID:PID = 2961:66b0, bus.address = 2.17).
Notifying user of session error: "generic/unspecified error"
if I then used the device drop down menu to attempt to connect again the following is added to the log file.
sr: device: sysclk-sla5032: Device instance already active, can't re-open.
I have just started to look at the USB dialog with Wireshark to get more details.
There was a PCB redesign last year changing it to a single PCB. My board is labeled SLA5032_2019A.
Maybe the new card is not compatible with Pulseview?
