Author Topic: Small Kelvin clips that actually grab?  (Read 6518 times)
Offline precaudTopic starter
    • LinearZ
« on: November 19, 2020, 01:49:58 pm »
All of the small (2" or less in length) Kelvin clips I have tried are practically useless, their contact surfaces don't have serrations deep enough to hold onto anything. Most larger clips are pretty good in this respect. But the small ones for some reason are all very smooth.
I've tried generics from China (see pic below), and domestic-branded ones. No difference. Except price...
Does anyone know of a small Kelvin clip that actually has usable teeth?
    • LinearZ
Re: Small Kelvin clips that actually grab?
« Reply #1 on: November 20, 2020, 03:40:52 pm »
Bump...
The following users thanked this post: CDN_Torsten
Offline Stray Electron
« Reply #2 on: November 20, 2020, 05:25:21 pm »
  I bought these and I'm happy with them https://www.amazon.com/gp/product/B071SL6PQS/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1 They're not Kelvin clips but they can be used in a Kelvin arrangement. Just clip the two leads from the voltage sense circuit as close to the body of the DUT as possible and connect the two leads from the current source out beyond those two.
    • LinearZ
« Reply #3 on: November 20, 2020, 09:14:48 pm »
Thanks, but that wouldn't work for me. I need a Kelvin clip arrangement with small contact area, not separate leads.
« Reply #4 on: November 20, 2020, 09:23:42 pm »
Dremel mods time ?
Online Martin72
  • Testfield Technician
« Reply #5 on: November 20, 2020, 09:41:47 pm »
You could use these ones:
https://www.distrelec.de/Web/Downloads/_t/ds/BU-30C_eng_tds.pdf
And solder/crimp two leads at the same point of the clip.
    • LinearZ
« Reply #6 on: November 20, 2020, 09:53:25 pm »
Dremel mods time ?
Yeah, I've considered that and similar, but didn't want to bugger the plating.
Not a true Kelvin, but a fallback...
Online Martin72
« Reply #7 on: November 20, 2020, 09:57:37 pm »
Not a true Kelvin
Here they did the same I suggested and call it kelvin clamps:
https://www.sourcetronic.com/shop/de/kelvin-test-clips-st26027a.html
You get the "best" results, when you´re measuring the voltage as near as possible to the point you feed in the current.
    • LinearZ
« Reply #9 on: November 20, 2020, 11:21:28 pm »
Those are the large clips, of which I have several. I want the small ones for this.
Online Electro Fan
« Reply #10 on: November 20, 2020, 11:43:41 pm »
Oh, that's what 2" or less means in length means  :)
I should have read your post more closely :palm:
None of the ones I tried were close to 2"; all were about 3.5" in length.  Only other idea is to try 4 small (~2") Pomona or Pomona-like (E-Z Hook) mini grabbers - just not sure how much "grab" you need.
These E-Z Hook grabbers are the shortest (~2.25") single mini-grabber types I've seen that have some sorta/kinda semi-decent (but not real great) "grab", and the molded housings on the stackable banana plugs are better than the screw on plastic cover version.  They come in various lead lengths.
If you find small, good grabbing, reliable measuring Kelvin clips let us know.
« Last Edit: November 21, 2020, 12:19:41 am by Electro Fan »
    • LinearZ
« Reply #11 on: November 21, 2020, 03:49:18 am »
I definitely will post if I find something. I don't wanna mess with individual grabbers. Sometimes there woudn't be enuf room for them anyway. The 2" clips I have would be fine if they didn't slip off so easily.
    • LinearZ
« Reply #12 on: November 21, 2020, 03:53:11 am »
Those look real enough. The sense terminals are probably on the other side of the insertions. GenRad and Wayne Kerr made clip sets that attached like that.
« Reply #13 on: November 21, 2020, 04:41:13 am »
Dremel mods time ?
File a little of the metal off where it doesn't matter to check what's under the plating.
Online Martin72
« Reply #14 on: November 21, 2020, 10:32:31 am »
Well.....I´ve totally forgot that I´ve already got small clips with good grip... ::) ;)
They came with my Ascel milliohm meter and got a nice building quality.
Grip is good, a small resistor with 0.8mm diameter leads they can handle it with no problems.
« Last Edit: November 21, 2020, 11:18:53 am by Martin72 »
Online Electro Fan
« Reply #15 on: November 21, 2020, 03:54:50 pm »
Ascel are just about 4”, OP is looking for 2” or less.  Kind of hard to find such mini Kelvins so far....
    • LinearZ
« Reply #16 on: November 21, 2020, 04:31:10 pm »
I bought them a couple years ago from China via eBay. IIRC, they were advertised as "solid brass" with gold plating. But since a magnet picks them up, it's obvious what they really are...
These ones are new since I last looked:
https://www.ebay.com/itm/283109177832
They are described as "pure copper", gold-plated. The teeth actually look like they could bite. So I ordered a couple sets. If they're steel, he can eat them.
« Last Edit: November 21, 2020, 04:36:13 pm by precaud »
Online Electro Fan
« Reply #17 on: November 21, 2020, 04:38:56 pm »
Hard to beat that price with free shipping.
    • LinearZ
« Reply #18 on: November 21, 2020, 06:17:22 pm »
I think they both may be an error.  But then, this seller looks like he sells closeouts/overstocks, or just about anything he can get his hands on :)
« Reply #19 on: November 21, 2020, 06:35:38 pm »
Don't be too judgemental until you pull one completely apart.
The spring of course should be steel as too the pivot and any fastenings.
You'll need a small mechanics pickup magnet to find which bits are and which bits aren't.
Then just to throw another apanner in any conclusions, some stainless is magnetic too.
Online Electro Fan
« Reply #20 on: November 21, 2020, 07:30:02 pm »
Why all the wires with these clips?  What is the wiring strategy?
    • LinearZ
« Reply #21 on: November 21, 2020, 08:02:37 pm »
That's what I used. My hamhandedness requires that I keep it handy...
That particular set was for an HP 4328A. Using multiple wires to lower the inductance allowed me to use a longer lead length than they specified. I have a similar setup that I use for HP 4800A. But it's not a 4-wire setup.
« Last Edit: November 21, 2020, 08:06:11 pm by precaud »
Online Electro Fan
« Reply #22 on: November 21, 2020, 09:05:50 pm »
http://www.testequipmenthq.com/datasheets/Keysight-4328A-Datasheet.pdf
cool!
    • LinearZ
« Reply #23 on: November 21, 2020, 10:39:29 pm »
Online Electro Fan
