Author Topic: SMB connectors, cable and crimping tool suitable for HP863E cable repair.  (Read 393 times)
Offline djsbTopic starter
Can anyone recommend any SMB connectors, matching cable and a suitable crimping tool that can be used to repair a few internal cables on an HP/Agilent HP8563E spectrum analyser? I do not have any experience working with these cables, and I will only need to repair maybe one or two at the most. I may get the cables made up by a specialist if this makes more sense. Is it also a good idea to change the matching PCB mounted connector at the same time? Any suggestions? Thanks.
PS These are definitely right angle SMB connectors but not sure if male or female are needed. The cables (RG174? Not sure) are also in different colours. The instrument is in storage nearby, so I can check tomorrow.
« Last Edit: February 08, 2025, 07:55:39 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline Harry_22
Re: SMB connectors, cable and crimping tool suitable for HP863E cable repair.
« Reply #1 on: February 08, 2025, 08:20:57 pm »
Hi David!
It is not a problem for the specialist to repair any internal cable with crimped connectors.
Would you attach the photos to do the diagnosis.
« Reply #2 on: February 08, 2025, 08:54:31 pm »
Thanks for your reply.
I've not actually identified a faulty cable yet. I'm making initial enquiries based upon a suggestion made to me by Keysight UK.
Once I've found the culprit (if indeed that IS the problem) I'll post the gory details. Please bear with me. Thanks.
Hertfordshire, UK
Offline Kean
    • Kean Electronics
« Reply #3 on: February 09, 2025, 04:18:50 pm »
Instead of making them yourself, maybe get some premade ones from Superbat RF.
https://www.rfsupplier.com/c/smb-cable_0303
e.g. straight https://www.rfsupplier.com/smb-plug-to-smb-plug-cable-using-rg174-coax_p6458.html
or right angle https://www.rfsupplier.com/smb-plug-right-angle-to-smb-plug-right-angle-cable-using-rg174-coax_p6490.html
They may not be up to the same original quality/frequency/loss specs, but depending on the problem you are trying to solve they may help prove or disprove a theory reasonably cheaply.
The following users thanked this post: djsb
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: February 09, 2025, 05:02:53 pm »
It's not too difficult. I made a pair for an hp 54501A scope. See the pics. Yea I used RG174 and a crimping tool that you can get various dies for you just get the die size and put it in the general purpose crimper. FYI the damaged BNC was a before pic.  ;)
The following users thanked this post: djsb, garrettm
