Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1960460 times)
0 Members and 12 Guests are viewing this topic.
Offline AndersAnd
Re: Sniffing the Rigol's internal I2C bus
« Reply #1875 on: December 10, 2013, 08:38:26 pm »
Just a thought but since theres so much information around and mostly spread across this forum thread i think its time a lot of the facts are consolidated in same way.
Unless someones already done it i can host a wiki on one of my jap based VPS's,...
The member "Avotronics" is already working on somthing like this here http://rigol.avotronics.co.uk
I can also mirror the keygen since its mostly javascript correct? Then eventually setup a firmware archive of sorts...
Avotronics has already mirrored the http://riglol.3owl.com keygen here http://rigol.avotronics.co.uk/mirrors/riglol/
But of course you could always set up another mirror.
« Last Edit: December 10, 2013, 08:40:56 pm by AndersAnd »
Offline alank2
« Reply #1876 on: December 10, 2013, 08:59:34 pm »
thx cosmos - will see if i find code for it.
Can somebody with JTAG query this data to see what is there - that might be pretty enlightening.
Offline cosmos
« Reply #1877 on: December 10, 2013, 09:10:03 pm »
Keep in mind that this will be accessed trough the FPGA fabric, this means it can easily be obfuscated so it might not be a nice contiguous memory area.
Offline apelly
  • Probe
« Reply #1878 on: December 10, 2013, 10:44:21 pm »
and as far as I know, no A-model owner has attempted to just downgrade to a v.1 firmware, run the keygen, and then upgrade back to v.2 (not sure why).
Busy with life. Maybe today.
Offline apelly
  • Probe
« Reply #1879 on: December 10, 2013, 11:00:05 pm »
There is already a wiki at http://www.eevblog.com/wiki/
I'll help if you like.
Offline AndersAnd
« Reply #1880 on: December 10, 2013, 11:01:27 pm »
Ordered a bus blaster tonight. Will be here in a week or so. Plan is to extract the 2072A firmware.
Have you received your Dangerous Prototypes Bus Blaster yet? Maybe it would be best to do a JTAG memory dump on your DS2000A scope before modding it?
Noone has posted a JTAG memory dump from DS2000A yet.
Which Bus Blaster version did you order, v3 or v4?
Bus Blaster v3 http://www.seeedstudio.com/depot/bus-blaster-v3-p-1415.html
Bus Blaster v4 http://www.seeedstudio.com/depot/bus-blaster-v4-p-1416.html
Offline alank2
« Reply #1881 on: December 10, 2013, 11:10:49 pm »
Is there a JTAG memory dump from the DS2000 somewhere?  Where?
Offline alank2
« Reply #1882 on: December 10, 2013, 11:27:08 pm »
Dave's teardown talks about a Lattice Mach IO PLD - any idea what would be the likely way the Blackfin would communicate with this?
Offline AndersAnd
« Reply #1883 on: December 10, 2013, 11:41:48 pm »
I think cybernet has done a JTAG dump: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg241335/#msg241335
But I'm not sure he has uploaded it, but you could try to ask him for it.
Offline apelly
  • Probe
« Reply #1884 on: December 10, 2013, 11:52:06 pm »
Hasn't arrived yet. Did get a shipping note a few days ago. Will check the post box this afternoon.
You raise a good point. I will get what I can with JTAG before I dick around with the firmware.
v4
Carrington has given me his notes and data for emulating a JTAGkey, but that might still take a while to set up.
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #1885 on: December 10, 2013, 11:59:05 pm »
via SPORT
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
Offline alank2
« Reply #1886 on: December 11, 2013, 12:04:31 am »
via SPORT
I've decoded the LDR streams and then loaded them into IDA.  I can see about a dozen subs that contain SPORT registers, but no SPORT0_RX or SPORT1_RX...
Offline cybernet
« Reply #1887 on: December 11, 2013, 12:54:28 am »
study the bfin manual with regards to DMA ;)
___________________
R0=-0x18;
UNLINK;
RTS;
Offline cosmos
« Reply #1888 on: December 11, 2013, 01:05:45 am »
Maybe I am blind but I don't see any candidates for a Lattice PLD (except maybe the small clock generation device next to the ADC and sample FPGA).
When in the teardown was this? and was he talking about the DS2k?
Offline cybernet
« Reply #1889 on: December 11, 2013, 01:06:34 am »
keyboard/leds on the frontpanel
___________________
R0=-0x18;
UNLINK;
RTS;
Offline cosmos
« Reply #1890 on: December 11, 2013, 01:11:36 am »
Duh... That makes sense yes.
Not so interested in that I guess, must have been absent minded watching that part.
Offline Carrington
« Reply #1891 on: December 11, 2013, 01:59:54 am »
Is this correct?
IMHO would be interesting know the entire table, and thus activate the desired options with a single key.
Code table: Use DSYX for a official key, and use VSYX for a trial key.
Y  CAN, 300, 50ohm
A   none
B   ==   ==   on
C   ==   on   ==
D   ??   ??   ??
E   on   ==   ==
F   ??   ??   ??
G   ??   ??   ??
H   on   on   on
J   ??   ??   ??
K   ??   ??   ??
L   ??   ??   ??
M   ??   ??   ??
N   ??   ??   ??
P   ??   ??   ??
Q   ??   ??   ??
R   ??   ??   ??
S   ??   ??   ??
T   ??   ??   ??
U   ??   ??   ??
V   ??   ??   ??
W   ??   ??   ??
X   ??   ??   ??
Y   ??   ??   ??
Z   ??   ??   ??
« Last Edit: December 11, 2013, 02:06:40 am by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline fcab100
« Reply #1892 on: December 11, 2013, 09:12:07 am »
DSA9 through DSH9
D S * 9    AT   DC  CAN  MD  100  200  300   unknown
      A       ON  ON    =    ON   ON   ON    =        =
      B       ON  ON    =    ON   ON   ON    =        *
      C       ON  ON    =    ON   ON   ON   ON       =
      D       ON  ON    =    ON   ON   ON   ON       *
      E       ON  ON   ON   ON    ON   ON   =        =
      F       ON  ON   ON   ON    ON   ON   =        *
      G       ON  ON   ON   ON    ON   ON  ON      =
      H       ON  ON   ON   ON    ON   ON   ON     *
I have not found what * dose yet.
The "*" unknown option dose not turn on 50ohm for my DS2072 HW 2.
Also tried DSI9 through DSZ9. Got license unavailability.  I'm guessing its not a good idea to use DS*9 option same as before.
« Last Edit: December 11, 2013, 09:29:20 am by fcab100 »
Offline eV1Te
  • Your trusted friend in science!
    • richardandersson.net
« Reply #1893 on: December 11, 2013, 12:35:16 pm »
New firmware is out for DS1000Z, version 00.02.01.SP1
It has quite a lot of bug fixes and seems to have faster GUI as well.  :-+
Now its possible to export the full memory of points as wfm files, but I have not found any software that supports these files, either to open or convert them... Does Rigol have any software for this?
« Last Edit: December 11, 2013, 03:42:30 pm by eV1Te »
Offline AndersAnd
« Reply #1894 on: December 11, 2013, 01:22:56 pm »
Nice, can you please share the file?
Offline Carrington
« Reply #1895 on: December 11, 2013, 02:58:34 pm »
@fcab100 I believe that you are mixing tables. X variable was defined in the nex table, so DSY9 enable (200, 100, Men, Dec and Trig).
The table to which I refer is only for Y. If I'm not mistaken Y variable directly affects only to the new features.
Cheers.  :)
X  200, 100, Mem, Dec, Trig
A   none
B   ==   ==   ==   ==   on
C   ==   ==   ==   on   ==
D   ==   ==   ==   on   on
E   ==   ==   on   ==   ==
F   ==   ==   on   ==   on
G   ==   ==   on   on   ==
H   ==   ==   on   on   on
Note: keys A..H wont change the model, only ADD an option.
2102:
J   ==   on   ==   ==   ==
K   ==   on   ==   ==   on
L   ==   on   ==   on   ==
M   ==   on   ==   on   on
N   ==   on   on   ==   ==
P   ==   on   on   ==   on
Q   ==   on   on   on   ==
R   ==   on   on   on   on   <-  All 2102
2202:
S   on   ==   ==   ==   ==
T   on   ==   ==   ==   on
U   on   ==   ==   on   ==
V   on   ==   ==   on   on
W   on   ==   on   ==   ==
X   on   ==   on   ==   on
Y   on   ==   on   on   ==
Z   on   ==   on   on   on   <-  All 2202
DONT USE BELOW Not recommended, as activates 2102 and also 2202:
2   on   on   ==   ==   ==
3   on   on   ==   ==   on
4   on   on   ==   on   ==
5   on   on   ==   on   on
6   on   on   on   ==   ==
7   on   on   on   ==   on
8   on   on   on   on   ==
9   on   on   on   on   on
Space Weather.
Offline Git
  • Very old engineer with over 4 decades in design.
« Reply #1896 on: December 11, 2013, 03:18:25 pm »
Has the key and/or serial number format changed?
Git
Offline NikWing
« Reply #1897 on: December 11, 2013, 03:46:40 pm »
does the shop where you bought the DSO send you the updates?
I wonder if the waveform gen in the S version is limited, too
I found little to no information about this new DSO yet ...
and it seems I have to wait until January until I can obtain one :/
btw, just want to say this: I really repect what you people did here ... I wish I would know how cybernet (for example) did all this reverse engineering stuff ... wow :)
« Last Edit: December 11, 2013, 03:48:38 pm by NikWing »
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #1898 on: December 11, 2013, 03:53:45 pm »
No.
I'm not sure exactly which DSO you mean, but Rigol has published fairly detailed datasheets for both the DS2000A-S series, as well as the DS1000Z-S series.
Just look for the specs of the waveform generator down near the bottom in the "Signal Source (DSXXXXX-S)" section.
« Last Edit: December 11, 2013, 03:57:57 pm by marmad »
Offline eV1Te
« Reply #1899 on: December 11, 2013, 03:54:24 pm »
Here is the new firmware for the DS1000Z and DS1000Z-S
Version 00.02.01.SP1
Too large to attach as a single file, so here is link to my FTP:
ftp://eevblog:555@ev1te.myftp.org/DS1000Z(ARM)update00.02.01.rar
