Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1960207 times)
0 Members and 14 Guests are viewing this topic.
Offline alank2
Re: Sniffing the Rigol's internal I2C bus
« Reply #2100 on: December 23, 2013, 05:52:36 pm »
DSHH includes a bit no one knows what it does.  DSGH is all bits that are known for 300mhz,can,trig,mem,decode
GH = 00110 00111
HH = 00111 00111
« Last Edit: December 23, 2013, 05:56:43 pm by alank2 »
Offline m-joy
« Reply #2101 on: December 23, 2013, 06:02:26 pm »
GH = 00110 00111
HH = 00111 00111
Lol the magic bit =) and What about 200mhz for the DSGH combination?
Offline alank2
« Reply #2102 on: December 23, 2013, 06:05:19 pm »
Neither the 200m or 100m are set in the final "H".  I'm not so sure it is a good idea to set any of the bandwidth ones together, then again I'm not so sure it matters either.  But 300M on its own works so that is the simplest.
Offline m-joy
« Reply #2103 on: December 23, 2013, 06:10:32 pm »
Thx. So What is the hex code for all Options and 300mhz but no 200mhz?
Offline alank2
« Reply #2104 on: December 23, 2013, 06:15:10 pm »
I'm using DSGH:  00011 10000 00110 00111
Note the 0's between the 3rd and 4th group.  The last 0 of the third group is the unknown bit.  The first two 0's of the fourth group are the 200m and 100m that are not needed.
Offline m-joy
« Reply #2105 on: December 23, 2013, 06:25:17 pm »
[Thx. So What is the hex code for all Options and 300mhz but no 200mhz?
SYSTEM:OPTION:UNINSTALL
first
"first"?
Offline apelly
  • Probe
« Reply #2106 on: December 23, 2013, 06:29:56 pm »
Offline neslekkim
  • Country: no
« Reply #2107 on: December 23, 2013, 06:32:03 pm »
did you jtag dump the device?
Offline Carrington
« Reply #2108 on: December 23, 2013, 06:38:19 pm »
Sorry about the quality.
No problem. Thanks again.
In the input stage they also change a bipolar trt!!! What is the SMD marking code? R2W..? -> BFR93A?
« Last Edit: December 23, 2013, 07:13:26 pm by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline Carrington
« Reply #2109 on: December 23, 2013, 06:52:44 pm »
I think that the input stage was improved, and probably it reach more than 350 MHz.
Will there any v1.0.x.. HW with some of these changes?
« Last Edit: December 23, 2013, 07:13:40 pm by Carrington »
Space Weather.
Offline apelly
  • Probe
« Reply #2110 on: December 23, 2013, 06:54:28 pm »
No bus blaster yet. Will check the mail today. Xmas has stuffed postage in this part of the world.
Offline Carrington
« Reply #2111 on: December 23, 2013, 06:56:34 pm »
Jumpers:
HW v1.0:
A or v2.0:
Space Weather.
Offline Carrington
« Reply #2112 on: December 23, 2013, 06:58:20 pm »
Mode 0 and Mode 1?
Also in version 1.0, but for what are they? USB mode? DSP?
« Last Edit: December 23, 2013, 07:04:40 pm by Carrington »
Space Weather.
Offline apelly
  • Probe
« Reply #2113 on: December 23, 2013, 07:06:54 pm »
This might be a better pic. JPEG compression instead of scaling.
Offline PA0PBZ
« Reply #2114 on: December 23, 2013, 07:08:11 pm »
Oooh, jumpers! Should I?  :-/O
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #2115 on: December 23, 2013, 07:09:23 pm »
The one you ordered ~4 weeks ago which was supposed to arrive 'in a week or so'?  Somebody is screwing with you... ;)
Then again, perhaps New Zealand is the last stop for Worldwide mail... ;D
« Last Edit: December 23, 2013, 07:11:25 pm by marmad »
Offline Carrington
« Reply #2116 on: December 23, 2013, 07:16:04 pm »
A lot better. Thanks.  :-+
Space Weather.
Offline Carrington
« Reply #2117 on: December 23, 2013, 07:19:16 pm »
The China-Spain mail takes about 3 weeks to a month.
Space Weather.
Offline neslekkim
  • Country: no
« Reply #2118 on: December 23, 2013, 07:24:37 pm »
same here, my orders from seeed usually takes around 3 weeks to Norway, it's free or almost free, so I don't complain.
Offline apelly
  • Probe
« Reply #2119 on: December 23, 2013, 07:28:50 pm »
Last time I looked at the tracking number (a week or two ago) the bloody thing was in Europe somewhere. uRuler anyone?
Edit:
Misread last time apparently. Shipped by Swiss post. There seems to be no tracking info available. I will follow up after I have checked the mail today.
And you were correct marmad: I did order the bloody thing around a month ago. Time flies.
« Last Edit: December 23, 2013, 07:45:15 pm by apelly »
Offline Carrington
« Reply #2120 on: December 23, 2013, 07:35:47 pm »
Another issue:
The oscilloscope flash probably contain calibration values closely associated with all the characteristics of input stage (a kind of fine settings adjustments). Something like the attached file (from Owon SDS oscilloscopes). So, modify the input stage may not be a good idea.
Or am I wrong?  :-//
« Last Edit: December 23, 2013, 07:37:28 pm by Carrington »
Space Weather.
Offline Carrington
« Reply #2121 on: December 23, 2013, 07:41:13 pm »
@ apelly:
Have you read this?
https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg350129/#msg350129
Maybe my method (TopJTAG Flash Programmer) to download the flash is not valid for hacking. Cybernet should know better.
« Last Edit: December 23, 2013, 07:44:53 pm by Carrington »
Space Weather.
Offline apelly
  • Probe
« Reply #2122 on: December 23, 2013, 07:50:31 pm »
Have you read this?
Yes.
Figured I'd cross that bridge when I came to it.
Frankly, I'm surprised nobody else has beaten me to it.
Offline Carrington
« Reply #2123 on: December 23, 2013, 07:54:33 pm »
Have you read this?
Yes.
LOL...
They are waiting for someone to do it for them.
Space Weather.
Offline Pehtoori
« Reply #2124 on: December 23, 2013, 09:05:39 pm »
LOL...
Or "they" don't have skill to do it, don't have it yet or don't have job so can't lose warranty from 850€ equipment.
I tick at least last 2 of them atm  :-\
Thats why I suggested fundraising to get one to be hacked. I would happily put >=20€  for it...
