Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1904200 times)
Offline neslekkim
  • Country: no
Re: Sniffing the Rigol's internal I2C bus
« Reply #2450 on: January 13, 2014, 08:39:19 pm »
But how is the process of buying a key?, what is collected from the scope to enable the correct key to the user?
If they change keys often in the scope, that would make it harder for Rigol, no?
Offline AndersAnd
« Reply #2451 on: January 13, 2014, 08:52:55 pm »
They need your Rigol's serial number when ordering a SW option. Their computer would know what key belongs to what serial numbers. It probably all computer automated so it wouldn't make it harder for them.
The bad thing is for customers is that a SW option is tied to a specific device, so if they break their device and have to buy a replacement, they will also have to pay for all the extra option keys again.
Offline NikWing
« Reply #2452 on: January 13, 2014, 09:02:15 pm »
Zombie28: what "production weeks" do you have atm?
Offline zombie28
« Reply #2453 on: January 13, 2014, 09:15:21 pm »
DS2202A: 42
DS2072A: 43, 44, 46
Offline NikWing
« Reply #2454 on: January 13, 2014, 09:20:30 pm »
that's the 2 digits after the ds2d15, right?
then I also have one from week 46
Offline neslekkim
  • Country: no
« Reply #2455 on: January 13, 2014, 09:41:15 pm »
my ds2202a-s is then week 46 if it is digit 7-8 in the serial
Offline zombie28
« Reply #2456 on: January 13, 2014, 09:42:45 pm »
PM sent, let us know if the keys match your scope
Offline hammy
« Reply #2457 on: January 13, 2014, 09:52:59 pm »
I would like to help and I'm ready to open my oscilloscope to JTAG this dump, but I'm not very familiar with in windows system JTAG,Can some guidance?
See posting #2447
A excellent tutorial!  :-+
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #2458 on: January 13, 2014, 09:58:51 pm »
See posting #2447
Also now linked to in the first post of this thread - in case you forget the number ;)
Offline hammy
« Reply #2459 on: January 13, 2014, 10:03:12 pm »
Good idea! Just answering the obvious questions. ;)
They all want to hack their scope, but don't take the time to read the thread. No pain, no gain!
Sometime the answer its just five messages away.  :scared:
« Last Edit: January 13, 2014, 10:23:13 pm by hammy »
Offline anson80
« Reply #2460 on: January 13, 2014, 10:47:49 pm »
If I say I almost from the beginning to see in the end, you will believe that?
Please forgive me, I like serious to read all the articles, but my English is not good,I think have A JTAG method different
I have seen posting #2446 , but like Linux operation
« Last Edit: January 13, 2014, 10:57:42 pm by anson80 »
Offline hammy
« Reply #2461 on: January 13, 2014, 10:57:25 pm »
I believe it.
Please forgive me, I like serious to read all the articles, but my English is not good, I think A and A through the JTAG method is different
I have seenposting #2447A , but like Linux operation
Ok. You only have windows and you want to know how to do the jtag dump with windows?
If someone provided already a dump from a scope from the same week like yours, it is not necessary to do this dump. In this case be nice to tirulerbach or zombie28 and ask for a key. Make more dumps and send the files to them!
This hacking here is an ongoing process. They all do great work. It needs time and a lot of effort!
« Last Edit: January 15, 2014, 11:31:23 pm by hammy »
Offline anson80
« Reply #2462 on: January 13, 2014, 11:21:59 pm »
I believe it.
If not -> just wait patiently. Maybe someday there will be a ready-to-use keygen for your scope.
Thank you for your help
I just want to give some help, I don't care whether can get keygen. I don't want to No pain
Offline granz
  • 6.62606957
« Reply #2463 on: January 14, 2014, 01:24:02 am »
Quick bandwidth measurement animation of my DS2072A after the keygen (now shows as DS2202A in system info).   It's a bit course because of the file size limitation.
I'll create a graph in the next few days which is more complete, but I thought I'd post this to help motivate people to provide more memory dumps.
Setup: Signal generator used was a Tektronix SG 503 Leveled Sine Wave Generator which goes up to 250 MHz.  Output was set at 2.00 Vpp (about +/- 5%) and verified with a 500 MHz scope over the frequency range shown.  All images are at the 5ns time base setting.  I'll include data from other time base settings in the graph.  (Obviously, 50 Ohms -to- 50 Ohms w/ 50 Ohm cable--same cable used to verify signal generator output with other scope).
You might notice that I couldn't actually get to the 3 dB point (~1.41 Vpp) with my signal generator due to it's limited output.  I guess I should build myself a fast pulse generator.
« Last Edit: January 14, 2014, 01:26:33 am by granz »
Offline AndersAnd
« Reply #2464 on: January 14, 2014, 01:26:50 am »
Any reason why you didn't upgrade to DS2302A instead of DS2202A?
Offline granz
  • 6.62606957
« Reply #2465 on: January 14, 2014, 01:33:01 am »
Actually, I tried that first.  It took the key but nothing happened except that the decode options were unlocked.  The model # stayed the same in system info and I didn't get the 2ns time base option, so I assumed it didn't take.
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #2466 on: January 14, 2014, 01:37:07 am »
2ns time base is already available on DS2202 models (as well as 100M BW limit). 1ns time base becomes available when 300MHz is unlocked.
Offline granz
  • 6.62606957
« Reply #2467 on: January 14, 2014, 01:43:59 am »
Yes, I understand that 2ns is normally available on DS2202 models, but mine started as a DS2072A with 5ns as the fastest timebase.  What I meant was that I first tried the 300MHz key, but still had only 5ns TB (no 2ns or 1ns) and no model number change (still claimed DS2072A).  When I then tried the 200MHz key it converted to a DS2202A with 2ns TB.  I didn't try the 300MHz key again after already converting it to a DS2202A, but maybe I should?
Tirulerbach can probably comment more, but he did say the 300MHz option was absolutely untested...
« Last Edit: January 14, 2014, 02:00:40 am by granz »
Offline AndersAnd
« Reply #2468 on: January 14, 2014, 02:03:10 am »
So the 4 letter options you have tried are NSEQ and NSFH?
For a appetizer look at the screenshot. Total running time is about 300ms...   O0
Offline granz
  • 6.62606957
« Reply #2469 on: January 14, 2014, 02:06:54 am »
Exactly.  I went with NSFH first and although it didn't reject the key, nothing happened (no model# change, still stuck at 5ns, no 100 MHz BW limit).  I guess this confirms that it doesn't work at this point?
I then went with NSEQ and that worked as expected (100 MHz BW, 2ns, model# change+plus shows 200MHZ installed option).
Offline AndersAnd
« Reply #2470 on: January 14, 2014, 02:09:23 am »
What about all the other options like CAN decoder bigger memory etc.? Were they not enabled with NSFH either?
Offline granz
  • 6.62606957
« Reply #2471 on: January 14, 2014, 02:20:06 am »
All trigger/decoder options including CAN were enabled with NSFH, I can't remember about the sample mem (but I think no), but there was definitely no BANDWIDTH option installed like there is now with NSEQ.  Essentially all NSFH did was remove the trial periods which hadn't yet expired.  Looking back I wish I had taken a screenshot.  I was mostly interested in seeing the 2ns and 1ns TBs and the 100 BW limit, which didn't become available until I used NSEQ (but no 1ns TB).
Hope that helps.
Is there anything known about the SMD jumpers and what they effect?  (Sorry if it's listed elsewhere)
« Last Edit: January 14, 2014, 02:28:19 am by granz »
Offline battlefield
« Reply #2472 on: January 14, 2014, 04:57:16 pm »
So I'm having one problem with my jtag connection. I connect all the wires as shown in the schematic, using Olimex ARM-USB-OCD and then run the command buergi ran (sudo ./bfin-gdbproxy...) and I get the following in my console:
debug:     bfin: bfin_open ()
Found USB cable: ARM-USB-OCD
Connected to libftdi driver.
warning: TDO seems to be stuck at 0
error:     bfin: detecting parts failed
error: Couldn't connect to suitable USB device.
error:     bfin: cable initialization failed
Also when I plug my JTAG cable in my computer the led turns green and as soon as I run the command it turns red. I'm using linux 12.04 LTS x64
Offline Flipp
« Reply #2473 on: January 14, 2014, 05:10:02 pm »
Is there any difference, if you do not connect the jtag side of the Olimex to anything? Is it possible to create a "working" jtag chain without any devices by shorting tdi and tdo pins together? Sounds like you have a break in the jtag chain or a fried input chip on your adapter.
Flip
Offline battlefield
« Reply #2474 on: January 14, 2014, 05:12:47 pm »
Nope, all the same no matter what I do -.-
Edit after shorting TDI and TDO and apllying 3.3V to VREF pin I got this
« Last Edit: January 14, 2014, 05:27:55 pm by battlefield »
