Hi Anders,
I used the windows KeyGen v.2.0b1 by synapsis
which was the most recent one I could find.
the code used was: DSAZ
Use this web-based RigLol keygen made by EEVblog member
studio25:
http://riglol.3owl.comUK mirror:
http://rigol.avotronics.co.uk/mirrors/riglol/Canadian mirror:
http://www.gotroot.ca/rigol/riglol/RigLol is the only keygen still maintained it seems, and it works on any operating system without installing anything. So there's no need to maintin different versions for Windows, Linux etc. RigLol is also very easy to use. Some have problems accesing the original site
http://riglol.3owl.com, so if you do, try one of the two mirror sites instead.
1) Uninstall all options.
2) Restore serial# using procedure described
here.
3) Upgrade to the latest FW 00.02.01.00.03.
4) Install DSEZ instead of DSAZ for 200 MHz with all options except for the 50 ohm option from the A-series.
Or instead install DSGH for 300 MHz with all options except for for the 50 ohm option from the A-series.
There's some debate whether 300 MHz works properly. Read marmad's and other's comments on this earlier in this in this topic and in the
DS2000 review topic.
DSEZ = DSAZ + CAN decoder option, but only works with the latest FW.
DSGH = same as DSEZ but with 300 MHz instead of 200 MHZ.
Read about DSEZ and how to build other letter combinations here:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg356379/?topicseen#msg356379y CAN, 300, 50ohm | x 200, 100, Mem, Dec, Trig
E on == == | Z on == on on on <- All 2202
G on on == | H == == on on on <- All 2302
Where y = 3rd letter and x = 4th letter:
DSyx = DSEZ for 200 MHz with all options except 50 ohm
DSyx = DSGH for 300 MHz with all options except 50 ohm
Read about and download the different DS2000 FW versions in this topic:
https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/
