Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1959725 times)
0 Members and 11 Guests are viewing this topic.
Offline NikWing
Re: Sniffing the Rigol's internal I2C bus
« Reply #2700 on: January 23, 2014, 09:25:13 pm »
that's really odd, my trial time decreased when it was online, not while switched off and with plug removed :o
Offline neslekkim
  • Country: no
« Reply #2701 on: January 23, 2014, 09:53:21 pm »
I think he means, in use of the features. Just turn on the scope, leave it on, and your trial will disapear, without using them..
Offline NikWing
« Reply #2702 on: January 23, 2014, 10:19:14 pm »
ahhh ok :D
misunderstood it then ^^
Offline diyaudio
« Reply #2703 on: January 23, 2014, 10:30:01 pm »
yeah. that's what I meant.
Offline pillex
« Reply #2704 on: January 24, 2014, 01:17:17 am »
Finally I managed to dump the memory of my DS2202A!
I was using a OpenOCD, FTDI2232D based JTAG device, pulling RDI, TMS, TCK and TDO up with 100k to 3V3.
I have uploaded the files to https://mega.co.nz/#!jkRihazT!L2KUHS3tb9nUPgqU1UBUD5gWXdsmSG4Wht7jS3s_HXo
hoping that the experts can send me some keys to enable all features. Furthermore I hope this post will contribute to a purely SW based unlocking solution in the future.
Cheers
Pillex
Offline cepphus
« Reply #2705 on: January 24, 2014, 11:21:10 am »
OK,
I have an update after trying some more today.  I've gotten the Altera USB-Blaster JTAG adapter to work with the blackfin tool chain.  It seems to work fine on a 32-bit Linux box.
I now have a working gdb interface after starting bfin-gdbproxy and connecting to it.  I can freely access memory and registers at this point.
If anyone else is looking for a JTAG interface for this, the knock-off Altera one (called "mini") is < $10 on eBay (US).  Working on memory dump now.
Is this the JTAG that would work? I just got my 2072A and would just love to open it and play
http://www.ebay.com/itm/150943500360
Offline Git
  • Very old engineer with over 4 decades in design.
« Reply #2706 on: January 24, 2014, 01:01:19 pm »
Finally I managed to dump the memory of my DS2202A! ...
I have uploaded the files to...
.tar.xz ?. I have seen .tar.gz, but nothing on windows seems to recognize .xz. I tried renaming it to .tar and .tar.gz. What format is the archive please?. A search on google found linux people asking the same question :)
Later - 7z opens and extracts it. Should ds2k_00_sdram.bin have length of 128MB ?
Git
« Last Edit: January 24, 2014, 01:23:55 pm by Git »
Offline pillex
« Reply #2707 on: January 24, 2014, 01:13:46 pm »
@Git: xz might be more common in the Linux world --> http://en.wikipedia.org/wiki/Xz
So 7zip should do the job for windows.
Offline granz
  • 6.62606957
« Reply #2708 on: January 24, 2014, 02:26:13 pm »
Yes, that's the one.  In the JTAG connection diagram posted a little while back I used the second setup (pull-ups on TRST and SRST lines -- don't connect these to the programmer at all), but either way should work for you.
Good luck!
Offline neslekkim
  • Country: no
« Reply #2709 on: January 24, 2014, 02:27:59 pm »
and that one is fairly fast?
I guess it's better then to buy this, since I dont know how to use my ft2232h card..
Offline granz
  • 6.62606957
« Reply #2710 on: January 24, 2014, 02:37:56 pm »
If I remember right it took about 15-20 minutes to dump 32MB of DRAM.
For some unknown reason I couldn't communicate with it from the blackfin toolchain on 64-bit Linux or 64-bit Windows 7, so just keep that in mind.  It worked fine once I tried it on a fresh install of Lubuntu 32-bit.  I didn't investigate further after getting the memory dump.  I believe another forum member had a similar issue with a different programmer, so I believe it's something in the blackfin version of UrJTAG.  Just keep it in mind if you want to minimize wasted time.
Offline neslekkim
  • Country: no
« Reply #2711 on: January 24, 2014, 02:52:01 pm »
good to know, all my computers use 64bit os, so I guess I'll try from an virtualmachine then
Offline granz
  • 6.62606957
« Reply #2712 on: January 24, 2014, 02:57:52 pm »
Good thing to try.  If it works out for you, definitely post about your success, because I'm sure that would make it easier for lots of folks.
Offline Posterisan
« Reply #2713 on: January 24, 2014, 05:05:04 pm »
Here is my Memory Dump from Rigol DS2072A !
Serial #: DS2D1542.....
https://mega.co.nz/#!IEdgVbiR!7ylPllecGTVCT54WldU8zGFLoa4E1niOeGCFLcnEPfI
took me hours to get the dump - my segger jlink does not work ;-((
Andre
Offline neslekkim
  • Country: no
« Reply #2714 on: January 24, 2014, 05:11:16 pm »
Which firmware version is people having when taking a dump?, I want to upgrade, but not sure if one should dump before and after?
Offline ZeroAviation
« Reply #2715 on: January 24, 2014, 05:53:09 pm »
Good luck!
Excellent! I'm going to pick one up as well. (2-4 week delivery time sucks)
I assume I should restore factory firmware before doing the dump?
-Matt
Offline eurofox
    • Music
« Reply #2716 on: January 24, 2014, 08:52:22 pm »
Hi Gary,
short question, didn't follow the thread for a while: why do you need to downgrade? Don't the keys work for V. 01.08.00 anymore?
Kind regards
Gunb
He wrote it five messages before. See Reply #2463.
OK, thx!
Hmm, slowly this thread seems to need a TOC  ;D
Got my DSA 815-TG yesterday :)
I'm very happy with it, I upgrade it to the latest firmware version without problem and apply the options with the magic keygen without problems, now I leave it on to "clean" the trial versions, I suppose they will expire and disappear, it will be verified tomorrow.
eurofox
eurofox
Offline tirulerbach
« Reply #2717 on: January 24, 2014, 09:22:36 pm »
First make an upgrade, then make the dump...
Offline true
  • INTERNET
« Reply #2718 on: January 25, 2014, 02:33:04 am »
I might take a dump before or after the upgrade, just depends on the time of day.
But if you want to know if you should dump before or after, I would say during - get it started then go take a dump.
Offline gbot
« Reply #2719 on: January 25, 2014, 03:02:42 am »
Hey All,
I am ready to pull the trigger on a DS2102A. Has anyone confirmed that the innards of the 2072A to the 2202A are identical? Would I be able to view 200MHz signals without issue with the 2102A - assuming the appropriate "patches" have been applied? I would be more than willing to dump the memory to help the cause.
Cheers!
Offline bluesmoke
« Reply #2720 on: January 25, 2014, 10:45:54 am »
... It is hard to resist! :)
Offline tirulerbach
« Reply #2721 on: January 25, 2014, 12:26:58 pm »
I made my dumps on a 64 bit systems with no problems at all. I even don't think that 32/64 bit host makes any differences for a cross-toolchain. I suppose that the mentioned problems on that particular case had another cause and the conclusion that it is a 64 bit issue is simply wrong.
Offline granz
  • 6.62606957
« Reply #2722 on: January 25, 2014, 02:48:07 pm »
Well, I completely agree that it *shouldn't* make any difference at all.  The blackfin tools are literally the same pre-compiled binaries no matter what host you are on (they are 32-bit binaries).  The USB kernel-space driver could be very slightly different or something stupid with ioctl() is going on (this is my guess).  bfin-jtag/bfin-gdbproxy gets to the USB JTAG-cable device in this order: libftdi(user-space library)--->libusb(user-space library)--->usbfs(kernel-space driver).  Examining the bfin-jtag and bfin-gdbproxy binaries also shows that they have statically linked libusb and libftdi and they may have a problem such as this in the versions they used:
http://stackoverflow.com/questions/9258280/whats-different-between-compiling-in-32bit-mode-and-64bit-mode-on-64bit-os-abou
I've had these types of issues in the past with my own software at work.  I guess it's not really fair to say it's a 64/32 bit issue per se, probably more like a kernel compatibility configuration issue.  It's just easier to say 64 or 32-bit.
I'm curious: what variety/version of Linux did you use?
Offline Co6aka
« Reply #2723 on: January 25, 2014, 05:40:05 pm »
I suppose that the mentioned problems...had another cause...
FWIW, most of the 32-on-64 issues I've encountered turned out to be multiarch-related, and tracking them down and fixing them was not often straightforward... |O At least one was an upstream issue, which eventually got fixed; stuff just started working one day, immediately following an update. (Sometimes it's the other way around too... |O) Typically stuff just didn't work or worked incorrectly, with no or little indication of why. Sometimes running GUI apps from the terminal provides a hint, as does pouring over the logs.
(One of my favorite source code comment-gems is "Error reporting could be better." :-DD No, REALLY?)
...statically linked libusb and libftdi...
"DLL Hell" of the Linux world.
« Last Edit: January 25, 2014, 05:46:38 pm by Co6aka »
Co6aka says, "BARK! and you have no idea how humans will respond."
Offline thinwire
« Reply #2724 on: January 25, 2014, 10:46:32 pm »
Rigol DS2000(A) series oscilloscopes: When installing an option with usbtmc :SYSTem:OPTion:INSTall or uninstall all options with :SYSTem:OPTion:UNINSTall I detected that all system settings are reset to the default  :-- . To avoid this I wrote a linux command line utility to install/uninstall options with restoring system settings. It is based on libusb-1.0 and does not need a usbtmc kernel driver.
Install an option:
rigoltmc -o XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
Uninstall all options:
rigoltmc -u
Identify the device:
rigoltmc -i
This should return something like:
RIGOL TECHNOLOGIES,DS2072A,DS2D15XXXXXXX,00.02.00
Have fun!
