Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1959353 times)
Offline Loeti
Re: Sniffing the Rigol's internal I2C bus
« Reply #3425 on: July 24, 2014, 08:55:59 pm »
Does anyone here know if the same upgrade codes are used for DS1000Z and MSO1000Z units? Would Riglol work for MSO1000Z?
Hello,
I got my MSO1104Z-S today. Even if the Rigol order codes for the options are the same for the DS1000Z and MSO1000Z series,
unfortunately Riglol doesn't work for the MSO1000Z at the moment. The firmware version of the MSO1000Z is also V04.00,
but there must be something different. Different private key, different option code or something like this. I've tried some other
option codes like "MSAB" instead of "DSAB", or "DSBB" or "DSHB" like other models use but I haven't succeeded yet.
Michael
Offline trunc71
« Reply #3426 on: July 27, 2014, 07:14:38 pm »
My DS2072A will arrive this week and of course I'll give it a try to unlock the added value. The description of the unlock process with the patched firmware 00.02.01.00.03 is pretty straightforward but I have one question left.
On the server http://www.gotroot.ca/rigol/ are three different rigup versions. They have version numbers 0.1, 0.2 and 0.4. Which version is the correct one to upload the binary key file ? The latest which is 0.4 or 0.1 which is the one mentioned in the document "DS2072A Unlocking Guide" on the same server ?
My thanks to all contributors who have spent that much time to look into all this.
Mike
Offline AintBigAintClever
« Reply #3427 on: July 28, 2014, 11:56:27 pm »
0.4 should do nicely.
If for some reason your scope rejects the 300MHz+all features code, try creating NS8N and NSEH codes and applying both, as per this post.
Offline trunc71
« Reply #3428 on: July 29, 2014, 10:02:58 am »
OK, thanks. Seems that I'm well prepared now. I'll give it a try tomorrow.
Offline trunc71
« Reply #3429 on: July 30, 2014, 03:46:51 pm »
In the meantime I have successfully unlocked all options of my DS2072A.  :-DD
However it was not that easy as I thought. On my 64-bit Windows 7 none of the keys created with rigup worked. The DS did not respond at all when sending the final key. No error message or whatever. Nevertheless I've seen some messages with similar experience in the forum before. Therefore, I switched to a 32-bit Virtual machine and tadaaa it worked immediately. No idea what's wrong with my 64.bit OS. Finally, I installed the latest firmware and all licenses are still there.
Offline conte_vlad
« Reply #3430 on: July 30, 2014, 03:51:24 pm »
great  :)
I ask: what did not worked on 64 version? rigup or else ultra sigma that send serials?
Offline trunc71
« Reply #3431 on: July 30, 2014, 04:11:02 pm »
I cannot say what exactly didn't work on 64-bit. Rigup has created the keys and I tried to send them with ultra sigma and later with Telnet. In both cases I got no response from the DS2072A and the trial licenses were still active. I also tried the update tool which has been programmed by madcrow when I remember correctly. I this case I saw the congratulation screen of the update tool but when I checked the installed licenses I saw the trial ones, only.
On 32-bit I tried the manual procedure first and it worked. Interestingly, the keys created by rigup are exactly the same on both windows versions. It must be another problem, maybe something is wrong with the bus communication. I don't know.
Offline conte_vlad
« Reply #3432 on: July 30, 2014, 04:15:16 pm »
thanks for answer  :)
it seems rigup, as you said, works same as the keys are same, may be some comunication problems with 64 version.  I will do some test, I am afraid to open the unit  :-// but I will do
Offline mrflibble
« Reply #3433 on: July 30, 2014, 06:34:39 pm »
Probably the 64-bit windows version. IIRC the used crypto library had some 32 vs 64-bit issues (on linux as well). So if the windows binary has not been compiled with the correct flags that would indeed cause a mismatch between generated keys on 32-bit vs 64-bit platform.
So when in doubt using a 32-bit VM is a good workaround as already noted.
Offline trunc71
« Reply #3434 on: July 31, 2014, 06:49:47 am »
If that is really the case then I'd expect different keys on both systems. But they are identical what makes perfect sense to me. I have also created the keys with different rigup versions. Also identical. Therefore, when finally transmitting the key to the DOS, the unit cannot know on which system the key was created. But on 64-bit W7 I got no response at all from the DOS whereas on 32-bit I saw the progress bar etc. immediately. I may be completely wrong but at the moment I doubt that the issue has to do with the key calculation.
« Reply #3435 on: July 31, 2014, 08:03:30 am »
My keys were successfully applied using Ultra Sigma in Win7 64-bit, sounds like you had an issue with either drivers or the Ultra Sigma install. Well done getting it done anyway.  :)
« Last Edit: July 31, 2014, 08:05:24 am by AintBigAintClever »
Offline trunc71
« Reply #3436 on: July 31, 2014, 09:40:14 am »
That's what I first thought because I know that many people have successfully used W7 64-bit. But others didn't. In my case Ultra Sigma was able to communicate with the DOS and has read out the keys correctly with the *IDN? command. This worked for both 32- and 64-bit without problems. The :SYSTem:OPTion:INSTall command only worked on 32-bit for me. I don't know whether this is due to a driver problem but I do think that this is some kind of a communication problem that arises under not yet known circumstances.
Offline Alex_Ismagilov
  • Country: ru
« Reply #3437 on: August 02, 2014, 09:02:44 pm »
Hi all,
I'm very happy :) about upgrading my DS2202A-S to DS2302A-S+AllOptions.
Greetings from Russia
Greatest THANKS for guys who make it possible!
Some details:
Used this guide: http://gotroot.ca/rigol/D2072A%20Unlocking%20Guide.pdf
The wizard "DS2000A Upgrade Utility" - does not work. Can't see after flashing fw.
My device: DS2202A-S
Now DS2302A-S with all options :)
Serial: DS2E15xxxxxx
Software version: 00.02.01.00.03
Hardware version: 1.2.2.0.2
Thanks: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg409142/#msg409142
NSFH - ???? all option and NO CHANGE bandwidth :(
NS8Q - ???? all option and 300mhz
Alex.
Offline sethur
« Reply #3438 on: August 03, 2014, 04:06:04 pm »
Hi *,
I got an DS1074Z-S, but non of the generated keys worked for me.  :-\
Unfortunately Rigol added a 12h timer when several wrong keys have been entered. :(
I then ripped up the case and read out the W25X40B flash, tried another wrong key and re-read the flash again to find out where the 12h timer is located.
It seems to be a 32bit timer at location 0x78007.
The trail keys start at 0x78027.
Removing them from flash and reentering would give another trail period, I think...
Maybe someone out there has some interest and knowledge on hacking this?
Greets,
sethur
Offline PepeK
  • Country: sk
« Reply #3439 on: August 05, 2014, 09:07:04 pm »
Do I understand it properly that if DS 2072 A or MSO 2072 A has a hardware version 2.2 it is not possible to downgrade using an USB stick ? (and it works only for HW revision 2.0 ? )
Is the only working way opening the scope and dumping a memory with some JTAG tool as described in this forum ?
Offline AndersAnd
« Reply #3440 on: August 06, 2014, 04:27:50 pm »
It would be nice if the persons handling http://gotroot.ca/rigol/riglol/ and http://riglol.3owl.com/ could update their online version.
I have http://riglol.3owl.com/ updatet. Thank you for your work.
Great work! I have updated my mirror at http://gotroot.ca/rigol/ . The old version also remains for posterity.
Avotronics's UK mirror has been updated too.
Original made by studio25: http://riglol.3owl.com
Canadian mirror hosted by ve7xen: http://gotroot.ca/rigol/riglol/
UK mirror hosted by Avotronics: http://rigol.avotronics.co.uk/mirrors/riglol/
Offline 0xPIT
« Reply #3441 on: August 07, 2014, 07:27:05 am »
I'm new to the forum, thanks for your great work.
So I've got a new 2072A and I am currently trying to dump the beast,
I soldered a cable for my USB Blaster and started Dumping according to
post #2433, the Bfin is recognized nicely.
Dumping seems to work, but when it's finished, gdb spits out
dump binary memory ~/sdram.bin 0x00000000 0x07FFFFFF
Ignoring packet error, continuing...
Reply contains invalid hex digit 116
and even as the process takes hours and I can see gdbproxy's debug out
to iterate over the address space, no file is written.
I've already increased gdb's remotetimeout without any change.
As the BF-Toolchain was not available for Mac and did not compile on first try,
I used a current Ubuntu on my old Atom Netbook to do the dump.
Update:
Now also tried with same '116' problem on my MacBook Pro in a Ubuntu 14.04 VirtualBox.
I've even tried several toolchains and gdbproxy/gdb combinations
Update 2 (solved using workaround):
I managed to extract a dump and generate Keys using this workaround:
in gdb, I used
    set debug remote 1
and
    set remotelogfile /tmp/log
Then I started a new dump, which failed at the end with the stated '116' error, but all responses from the Blackfin were logged as ascii hexdump in the logfile.
I then awk'd the logfile to include only lines starting with +r $ and then removed this string using vi (:%s/^r\ +$//g)
Now I used xxd -p -r to convert the hexdump to binary and ran rigup on it, which worked fine.
Greetings,
  - pit
« Last Edit: August 07, 2014, 03:19:50 pm by 0xPIT »
Offline asgard20032
« Reply #3442 on: August 08, 2014, 03:04:37 pm »
Im about to buy a DS1074z or a MSO1074z (maybe the -s variant), but I want to know if anyone here successfully hacked the MSO one/
Offline AndersAnd
« Reply #3443 on: August 08, 2014, 03:49:01 pm »
Same firmware. Makes no difference if it's DSO or MSO, or even S variant.
Offline asgard20032
« Reply #3444 on: August 08, 2014, 03:53:41 pm »
Its because of that I ask :
Hello,
Michael
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #3445 on: August 09, 2014, 01:02:09 am »
The search button and/or reading this thread would give you the answer.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline asgard20032
« Reply #3446 on: August 09, 2014, 01:36:20 am »
I read over 100 page on this thread, used the search on MSO1074z and MSO1000z, without more result than what I quoted and what we are talking since the last 3 post.
Offline miguelvp
« Reply #3447 on: August 09, 2014, 01:51:33 am »
https://www.eevblog.com/forum/testgear/rigol-ds1074z-oscillosope/msg434605/#msg434605
utility:
within utility you will find the following.
DS1000z device options:
DSAB - Advanced Triggers
DSAC - Decoders
DSAE - 24M Memory
DSAJ - Recorder
DSBA - 500uV Vertical
DSEA - 100MHz
DSFR - all options
But I have no idea about the MSO1074z then again you mentioned the DS1074z as well.
Edit: took me under 2 minutes (maybe even under 1 minute) to find it with the search button.
Offline asgard20032
« Reply #3448 on: August 09, 2014, 04:11:32 am »
I know for the DS1074z... im asking about MSO1074z
Offline Loeti
« Reply #3449 on: August 09, 2014, 09:10:23 pm »
I tried it with a DS1104Z-S, serial no. starting with "DS1ZB" -> works.
MSO1104Z-S, serial no. starting with "DS1ZD" -> doesn't work.
Maybe they have changed the algorithm or at least the private key and provided downward compatibility for the first DS1000Z scopes with "DS1ZB" serials.
Michael
