Hey Guys,
nice work
since I saw Crille77s post, I remembered I got a genuine USB-Blaster myself. I thought I would give it a try myself and unlock my MSO1104z.
So far, unfortunately, it hasn't worked ;(
First I tried Win7 (vm) and openocd in different configs, reinstalled usbblaster driver and ftdi multiple times.
PID/VID are default (checked), still openocd reports
Error: unable to open ftdi device: usb_open() failed in procedure 'init'
So far so good, thought maybe it is about the Windows being a VM, so I tried Linux Ubuntu 14.04.
On Linux I can get access to the JTAG and openocd 0.7.0 recognizes the usbblaster.
openocd -d2 -f interface/altera-usb-blaster.cfg -f target/imx28.cfg
Open On-Chip Debugger 0.7.0 (2013-10-22-08:31)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
debug_level: 2
Warn : Adapter driver 'usb_blaster' did not declare which transports it allows; assuming legacy JTAG-only
Info : only one transport option; autoselect 'jtag'
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
dcc downloads are enabled
Which looks good so far, but a few seconds after it outputs;
Info : This adapter doesn't support configurable speed
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: imx28.cpu: IR capture error; saw 0x0f not 0x01
Warn : Bypassing JTAG setup events due to errors
Info : Embedded ICE version 15
Error: unknown EmbeddedICE version (comms ctrl: 0xffffffff)
Info : imx28.cpu: hardware has 2 breakpoint/watchpoint units
Warn : WARNING: unknown debug reason: 0xf
Warn : ThumbEE -- incomplete support
Anyone any idea how to solve it?
Since it reports "all ones", I figuered that there may be pullups/pulldowns required, but in the post it did't look like it?
Regards
Fluxx1122
