Ok, I got it...
SRST is RESET I guess...
Anyway I issued the following command
sudo openocd -d1 -f interface/jlink.cfg -c "transport select jtag" -c "adapter_khz 6000" -f board/imx28evk.cfg -l ~/openocd_log
and the first time I got this:
Open On-Chip Debugger 0.9.0 (2016-09-30-19:43)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Error: Invalid command argument
new_level option value ('l') is not valid
jtag
adapter speed: 6000 kHz
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
dcc downloads are enabled
imx28evk_init
Info : J-Link ARM V8 compiled Nov 28 2014 13:44:46
Info : J-Link caps 0xb9ff7bbf
Info : J-Link hw version 80000
Info : J-Link hw type J-Link
Info : J-Link max mem block 9224
Info : J-Link configuration
Info : USB-Address: 0x0
Info : Kickstart power on JTAG-pin 19: 0xffffffff
Info : Vref = 3.448 TCK = 1 TDI = 1 TDO = 0 TMS = 1 SRST = 1 TRST = 1
Info : J-Link JTAG Interface ready
Info : clock speed 6000 kHz
Info : JTAG tap: imx28.cpu tap/device found: 0x079264f3 (mfg: 0x279, part: 0x7926, ver: 0x0)
Info : Embedded ICE version 6
Info : imx28.cpu: hardware has 2 breakpoint/watchpoint units
Info : accepting 'telnet' connection on tcp/4444
I mistyped -dl instead of -d1... Then I did the telnet connection and it worked!
Then I trid again the connection but added a new option, to save the output log of openOCD like this:
and I got this:
debug_level: 1
I hope this is OK...
Now I'm going foe the telnet connection again...
But before I want to ask another question:
What I'm doing is just a memory dump, right? Is this anyway dangerous to the scope? Can I brick the scope?
