Here's the generator code amended with "some guy"'s recommendation. Now it generates a VALID code for me w/o manually fiddling around with the seed.
So you can spare the seed field on the GUI...
Great work, the math problem was beyond me, but you didn't take into account preceding zeros in lic1 or lic2, which must be nullpadded to keep those variables at 14 characters long each.
I've added it to your code here:
** rigol ds2000 keygen / cybernet & the-eevblog-users
** to compile this you need MIRACL from [url]https://github.com/CertiVox/MIRACL[/url]
** download the master.zip into a new folder and run 'unzip -j -aa -L master.zip'
** then run 'bash linux' to build the miracle.a library
** BUILD WITH:
** gcc rikey.c -I../MIRACL ../MIRACL/miracl.a -o rikey
** adapt -I and path to miracl.a to your environment
** more info: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/
** then fetch private key from EEV Blog and put into "private_key[]=" below, do not prefix with 0x
** supply your serial and wanted options, and enjoy !
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <ctype.h>
#include <stdio.h>
#include "miracl.h"
#define RIGOL_DS2000
// START OF SETTINGS FOR ECC
#ifdef RIGOL_DS2000
unsigned char private_key[]="8..."; // <- RILOL FILL ME (no 0x prefix !)
unsigned char prime1[]="AEBF94CEE3E707";
unsigned char prime2[]="AEBF94D5C6AA71";
unsigned char curve_a[]="2982";
unsigned char curve_b[]="3408";
unsigned char point1[]="7A3E808599A525";
unsigned char point2[]="28BE7FAFD2A052";
#endif
// END OF SETTINGS FOR ECC
unsigned char codemap_ee00d0[]={ 0x0, 0x0, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0x2,
0x3, 0x4, 0x5, 0x6, 0x7, 0x0, 0x8, 0x9, 0xa, 0xb,
0xc, 0x0, 0xd, 0xe, 0xf, 0x10, 0x11, 0x12, 0x13, 0x14,
0x15,0x16, 0x17 };
unsigned char codemap_20688e[]={ 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, /* 0-9 = 0x30 */
0x37, 0x37, 0x37, 0x37, 0x37, 0x37 }; /* A-F = 0x37 */
unsigned char vb[]={'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'J', 'K', 'L', 'M', 'N', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '2', '3', '4', '5', '6', '7', '8', '9'};
void show_help(void)
printf("./rikey <DSA2XXXXXXXXX> <OPTS>\n\n");
printf("<DSA2XXXXXXXXX> - serial number of device\n");
printf("<OPTS> - \n");
printf("\t\tDSA? for permanent options\n");
printf("\t\tVSA? for temporary options\n");
printf("\n\n");
** take serial and options make sha1 hash out of it
static void hashing(unsigned char *opt_str,big hash)
{ /* compute hash function */
char *p;
char h[20];
int ch;
sha sh;
shs_init(&sh);
p=opt_str;
while(*p)
shs_process(&sh,*p);
p++;
shs_hash(&sh,h);
bytes_to_big(20,h,hash);
** sign the secret message (serial + opts) with the private key
int ecssign(unsigned char *serial, unsigned char *opt, unsigned char *lic1, unsigned char *lic2)
FILE *fp;
char ifname[50],ofname[50];
big a,b,p,q,x,y,d,r,s,k,hash,temps;
epoint *g;
long seed;
int bits;
miracl *mip;
unsigned char *serial_options;
/* Support variables for checking against divisibility */
int prime2_factors[] = {17, 53, 905461, 60291817};
int i;
int passed;
big tmp;
/* randomise */
seed=1;
srand(seed);
do {
passed = 1;
/* get public data */
mip=mirsys(0x320, 0x10); /* Use Hex internally */
mip->IOBASE=16;
a=mirvar(0);
b=mirvar(0);
p=mirvar(0);
q=mirvar(0);
x=mirvar(0);
y=mirvar(0);
d=mirvar(0);
r=mirvar(0);
s=mirvar(0);
k=mirvar(0);
hash=mirvar(0);
instr(p,prime1); /* modulus */
instr(a,curve_a); /* curve parameters */
instr(b,curve_b);
instr(q,prime2); /* order of (x,y) */
instr(x,point1); /* (x,y) point on curve of order q */
instr(y,point2);
ecurve_init(a,b,p,MR_PROJECTIVE); /* initialise curve */
g=epoint_init();
if (!epoint_set(x,y,0,g)) /* initialise point of order q */
printf("1. Problem - point (x,y) is not on the curve\n");
exit(0);
/* calculate r - this can be done offline,
and hence amortized to almost nothing */
bigrand(q,k);
ecurve_mult(k,g,g); /* see ebrick.c for method to speed this up */
epoint_get(g,r,r);
divide(r,q,q);
/* get private key of signer */
instr(d, private_key);
/* calculate message digest */
serial_options=calloc(128,1);
strcpy(serial_options, serial);
strcat(serial_options, opt);
hashing(serial_options,hash);
/* calculate s */
xgcd(k,q,k,k,k);
mad(d,r,hash,q,q,s);
mad(s,k,k,q,q,s);
/* check if we got a valid lic2 (s) */
tmp = mirvar(0);
for (i = 0; i < (sizeof(prime2_factors) / sizeof(prime2_factors[0])); i++) {
lgconv(prime2_factors[i], tmp);
if (divisible(s, tmp)) {
passed = 0;
srand(++seed);
break;
} while (!passed);
cotstr(r,lic1);
cotstr(s,lic2);
return 0;
** convert string to uppercase chars
unsigned char *strtoupper(unsigned char *str)
unsigned char *newstr, *p;
p = newstr = (unsigned char*) strdup((char*)str);
while((*p++=toupper(*p)));
return newstr;
unsigned char code_map_206846(unsigned char i)
if ((i >= 'A') && (i <= 'F')) return(i-0x37);
if ((i >= '0') && (i <= '9')) return(i-0x30);
return(0x0);
** Encryption Routine 1
unsigned char *lic_code_map(unsigned char *lic_skipped)
unsigned char lv1,lv2;
unsigned char b1_mapped, b1_shifted, b1_remapped;
unsigned char b2_mapped, b2_shifted, b2_remapped;
unsigned char b3_mapped, b3_shifted, b3_remapped;
unsigned char b4_mapped, b4_shifted, b4_remapped;
unsigned char b5_shifted, b5_remapped;
unsigned char *lic_mapbytes;
lic_mapbytes=calloc(28, 1);
if (!lic_mapbytes) return(0);
lv1=lv2=0;
while(lv1 < strlen((unsigned char*)lic_skipped))
b1_mapped = codemap_ee00d0[ *(lic_skipped+lv1) - 0x30 ];
b1_shifted = (b1_mapped / 2) & 0xf;
b1_remapped = b1_shifted + codemap_20688e[b1_shifted];
lic_mapbytes[lv2++]=b1_remapped;
b1_mapped = b1_mapped & 0x1;
b2_mapped = codemap_ee00d0[ *(lic_skipped+lv1+1) - 0x30 ];
b2_shifted = ((b1_mapped << 0x3) | (b2_mapped / 4)) & 0xF;
b2_remapped = b2_shifted + codemap_20688e[b2_shifted];
lic_mapbytes[lv2++]=b2_remapped;
b3_mapped = codemap_ee00d0[ *(lic_skipped+lv1+2) - 0x30 ];
b3_shifted = ((b3_mapped / 8) | ( (b2_mapped & 0x3) << 2 )) & 0xF;
b3_remapped = b3_shifted + codemap_20688e[b3_shifted];
lic_mapbytes[lv2++]=b3_remapped;
b4_mapped = codemap_ee00d0[ *(lic_skipped+lv1+3) - 0x30 ];
b4_shifted = ((b4_mapped / 16 ) |((b3_mapped & 0x7) << 0x1)) & 0xf;
b4_remapped = b4_shifted + codemap_20688e[b4_shifted];
lic_mapbytes[lv2++]=b4_remapped;
b5_shifted = b4_mapped & 0xF;
b5_remapped = b5_shifted + codemap_20688e[b5_shifted];
lic_mapbytes[lv2++]=b5_remapped;
lv1 = lv1 + 4;
return(lic_mapbytes);
unsigned char * find_match5(unsigned char *code5)
unsigned char c1,c2,c3,c4;
unsigned char *input;
input=calloc(40,1);
/* lets bruteforce it ;-) */
for (c1=0;c1<sizeof(vb);c1++) {
for (c2=0;c2<sizeof(vb);c2++) {
for (c3=0;c3<sizeof(vb);c3++) {
for (c4=0;c4<sizeof(vb);c4++) {
input[0]=vb[c1];
input[1]=vb[c2];
input[2]=vb[c3];
input[3]=vb[c4];
input[4]='\0';
lic_mapbytes=lic_code_map(input);
if (!strcmp(lic_mapbytes, code5))
return(input);
return(0); // no match
char *strrev(char *str)
char *p1, *p2;
if (! str || ! *str)
return str;
for (p1 = str, p2 = str + strlen(str) - 1; p2 > p1; ++p1, --p2)
*p1 ^= *p2;
*p2 ^= *p1;
*p1 ^= *p2;
return str;
int main(int argc, char *argv[0])
unsigned char *options,*lic1_code, *lic2_code, *lic_all;
unsigned char *out,*chunk,*temp,*final;
unsigned char *lic1_key, *lic2_key;
unsigned char *serial;
int v,i=0;
if (strlen(private_key)<14)
printf("\n\n");
printf("set the private_key variable on top of this file\n");
printf("you can find it here: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg264690/#msg264690\n");
printf("\n\n");
exit(-1);
if (argc != 3)
show_help();
exit(-1);
serial=strtoupper((unsigned char*)argv[1]);
options=strtoupper((unsigned char*)argv[2]);
if (strlen(serial)<13)
printf("\nINVALID SERIAL LENGTH\n");
show_help();
exit(-1);
if (strlen(options)!=4)
printf("\nINVALID OPTIONS LENGTH\n");
show_help();
exit(-1);
printf("serial: %s\n", serial);
printf("options: %s\n", options);
/* sign the message */
lic1_code=calloc(64,1);
lic2_code=calloc(64,1);
ecssign(serial,options,lic1_code, lic2_code);
int diff1 = 14 - strlen(lic1_code);
while(diff1 > 0) {
strrev(lic1_code);
strcat(lic1_code, "0");
strrev(lic1_code);
diff1--;
int diff2 = 14 - strlen(lic2_code);
while(diff2 > 0) {
strrev(lic2_code);
strcat(lic2_code, "0");
strrev(lic2_code);
diff2--;
printf("lic1-code: %s\n", lic1_code);
printf("lic2-code: %s\n", lic2_code);
lic_all=calloc(128,1);
temp=calloc(128,1);
chunk=calloc(6,1);
final=calloc(128,1);
lic1_key=calloc(20,1);
lic2_key=calloc(20,1);
strcpy(lic_all, lic1_code);
strcat(lic_all, "0");
strcat(lic_all, lic2_code);
printf("target-code: %s\n", lic_all);
// split in 5 byte groups and run bruteforce
// run or lic1_code
strcat(lic1_code,"0");
while(i<=strlen(lic1_code))
memcpy(chunk,lic1_code+i,5);
out=find_match5(chunk);
if (out)
strcat(temp, out);
i=i+5;
strcpy(lic1_key, temp);
// run for lic2_code
strcpy(temp,"");
i=0;
while(i<strlen(lic2_code))
memcpy(chunk,lic2_code+i,5);
if (strlen(chunk)<5)
for(v=0;v<5-strlen(chunk);v++)
strcat(chunk,"0");
if (out)
strcat(temp, out);
i=i+5;
strcpy(lic2_key, temp);
strcpy(temp, lic1_key);
strcat(temp, lic2_key);
// now add the options
memcpy(final, temp, 1);
final[1]=options[0];
memcpy(final+2, temp+1,7);
final[9]=options[1];
memcpy(final+10, temp+8,7);
final[17]=options[2];
memcpy(final+18, temp+15,7);
final[25]=options[3];
memcpy(final+26, temp+22,4);
printf("----------------------------------------------------\n");
printf("your-license-key: ");
for(i=0;i<strlen(final);i++)
if (i%7==0 && i>0) printf("-");
printf("%c", final[i]);
printf("\n");
