DS1000Z - remove the 500uV option - it does NOT work. It will let you go to 500uV but will push the signal low off the screen. I also don't think there is a bandwidth difference between the 70MHz and 100Mhz models - my rise test test shows >200MHz. See post #32 here:
https://www.eevblog.com/forum/testgear/rigol-ds1074z-inside-picture/msg337494/#msg337494
Alan, did you perform a SelfCal, and that didn't correct the shift?
That is true, you have a good point, let me try that!
Frequency Response Plots for DS2000 series 300Mhz firmware.
While doing these measurements I found that with Ch1 and Ch2 turned on, the displayed waveform does not change when switching between 1nS and 2nS/div. It is displayed as 2nS/div. The time/div readout changes but the only change to the displayed wave form is the trigger point.
If there is a frequency measurement active on the screen, it will read double the correct value when on the 1nS/div range.
The hardware freq counter reading remains correct .
With only one Channel turned on, all is well.
Rigol RP3300A probe, Jim Williams style pulse generator
My ds2072 (hacked to 200mhz) not update to ds2302 (300mhz), i bought other pendrive that was detected, but i haven't success again.
Can anybody help me ?
Thanks
I have not had time to test every feature, just got my DS1084Z-S today. Have you done the Self-Calibration after enabling 500 uV option? My unit had significant DC offset from factory, that disappeared after Self-Calibration.
Ok, I'll try uninstall the keys, but i dont know to do this.
I'll research the procedure to uninstall too.
Thanks Cybernet for your help, great work.
Interesting. Even after a self cal switching to 500uV for me pushed the signal off the screen... Maybe you have hardware that supports it and mine does not...
Interesting. Even after a self cal switching to 500uV for me pushed the signal off the screen... Maybe you have hardware that supports it and mine does not...On my DS1074Z the self calibration doesn't correct the DC offset too. Firmware version 00.02.00.SP1.
Just to clarify, I have not enabled 500 uV/div resolution on my scope. But I had ca. 0.5 div offset on 1 mV/div from factory, and that corrected it self quite well after self cal.
[cn@warpnas01 CUSTOM]$ ../../../DS2000_New/gelfile/geltool -f DS405XUpdate.GEL -c
model: DS4064
version: 00.02.00.00.04
bitmask: 0x7
num_of_sections: 0x10
section: #00: CRC:09081ED3 ADDR:20040000 LEN:3511236 OFS:488 [VALID CRC]
section: #01: CRC:D8B156BB ADDR:20000000 LEN:2574652 OFS:3511724 [VALID CRC]
section: #02: CRC:52C1A46B ADDR:20000000 LEN:69472 OFS:6830282 [VALID CRC]
section: #03: CRC:5B8BE417 ADDR:20020000 LEN:216136 OFS:6899754 [VALID CRC]
section: #04: CRC:35E14CB3 ADDR:200D6000 LEN:9434 OFS:7115890 [VALID CRC]
section: #05: CRC:D40982DF ADDR:200C8000 LEN:30964 OFS:7125324 [VALID CRC]
section: #06: CRC:C7AC2358 ADDR:200FA000 LEN:379408 OFS:7156288 [VALID CRC]
section: #07: CRC:694D10C1 ADDR:20120000 LEN:7508 OFS:7535696 [VALID CRC]
section: #08: CRC:E8B07094 ADDR:20000000 LEN:422268 OFS:7543204 [VALID CRC]
section: #09: CRC:3B9049C9 ADDR:20040000 LEN:12364 OFS:7965472 [VALID CRC]
section: #10: CRC:D2B695F5 ADDR:20000000 LEN:2916 OFS:7977836 [VALID CRC]
section: #11: CRC:3F1C1BCC ADDR:20000C00 LEN:247192 OFS:7980752 [VALID CRC]
section: #12: CRC:63503009 ADDR:201E4C00 LEN:10876 OFS:8227944 [VALID CRC]
section: #13: CRC:0A983326 ADDR:2003D400 LEN:37204 OFS:8238820 [VALID CRC]
section: #14: CRC:4B530B40 ADDR:20045000 LEN:768008 OFS:8276024 [VALID CRC]
section: #15: CRC:00000000 ADDR:20122800 LEN:0 OFS:9044032 [VALID CRC]
[cn@warpnas01 CUSTOM]$ ls -l *.GEL
-rwxr-xr-x 1 cn smbusers 9044032 Nov 27 18:15 DS4000Update.GEL
-rw-r--r-- 1 cn smbusers 9044032 Nov 27 18:24 DS405XUpdate.GEL
