No, I run the calibration and then the sweep again. Wait a moment!Quote from: marmad on December 16, 2013, 02:02:00 pm@EV: BTW, did you run the self-calibration after installing the 300MHz option (or before running the sweep)?
Then it seems even more illogical that they didn't sell a 300MHz version DS2000 a year and a half ago - unless it was only because of the lack of 50 Ohm input.
The true 50 Ohm input is propably better than this feed through terminator.
Ok, I run the self calibration and new sweep. Maybe there is a small improvement. BW seems to be now about 310 MHz.
Inverted -> after calibrated.
The gain after calibration is very, very small. Seems like the gain is within measurement noise. Am I wrong? I guess I was looking for a huge improvement.
EV,I'm not sure that I understand your measurement.You said that the signal generator is producing a sine wave sweep between 1MHz and 300MHz over a time span of 14 seconds (24.93MHz per second assuming a linear frequency sweep).The DS2000 display is showing that it's horizontal time base is set to 1 second per division and we see a waveform covering all 14 horizontal divisions of the display.We also see that the trigger point is off the left side of the display by 1.5 seconds (display shows trigger delay of 8.5 seconds minus 7 divisions of 1 second each).Wouldn't that mean that the actual sweep time from the generator is at least 15.5 seconds? If so, then the sweep would be 349/15.5 = 22.52MHz per second and the -3db point would be about 342MHz since there is an extra 1.5 seconds of sweep off the left side of the display (assuming the the sweep also ends at exactly the last graticule line of the display).Or are you manually triggering the scope and then centering the entire sweep on the display?
Is it True that there was an 200Mhz trial on the ds2072?Because i can not Find that on my ds2072A.if this option has been removed, maybe there can not be keys for activating higher bandwidth on A-models...?
I have a 2072 non A 1.0 hardware FW v.02.01.00.03 upgraded to a 2302 with DSHH. Was wondering if anyone else tried accessing the CAN trigger/decode by SCPIQuerying the current trigger with :TRIGger:MODE? works for all but CAN.Trying to set the trigger to CAN with :TRIGger:MODE CAN pops a message on the scope "Input is invalid":BUS1:MODE? will return CAN and :BUS1:MODE CAN will select CAN.But I couldn't access anything under :BUS1:CAN like :OFFSet
isnt it currently more efficient to buy an Rigol DS1074Z instead of ds2072A ? Because for the DS1074Z the serials seems to work because there is no A version...? And with options you have at least 100Mhz and stuff compared to the 70Mhz ds2072A and save money.Greets
