Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1854600 times)
Offline Mark_O
Re: Sniffing the Rigol's internal I2C bus
« Reply #3150 on: April 09, 2014, 05:18:55 am »
I think I've come across some sort of tamper-counter, ...
Nice way to spread FUD!   :-+
Offline MTD
  • Country: mk
« Reply #3151 on: April 09, 2014, 05:25:47 am »
I think I've come across some sort of tamper-counter, because now the scope has stopped responding to any license I throw at it, both over LAN and in the user interface (no 'license is unavailable' message anymore, no reaction whatsoever).. power off, etc, doesn't help..
Hmm, if you haven't tried already, I'm wondering.
How about uninstalling all the options?
:SYSTem:OPTion:UNINSTall
MTD
Offline Arkku
« Reply #3152 on: April 09, 2014, 07:14:06 am »
In addition to this it might be a good idea to reinstall the firmware (it can even be the official firmware since the keys were already dumped).
Offline hooverphonique
« Reply #3153 on: April 09, 2014, 09:40:34 am »
you mean uninstalling the trial licenses that came with it? because that's all that's installed.. I never succeeded in installing any licenses myself.. It kept saying "license is unavailable" until it stopped reacting at all...
I also tried reflashing it with official firmware, but it still doesn't respond to any license key entry, meaning I can enter the key, but when pushing apply, nothing happens at all, and it's the same using :SYST:OPT:INST over SCPI..
thanks for any suggestions, guys...
« Reply #3154 on: April 09, 2014, 11:46:39 am »
so I tried ':SYST:OPT:UNINST', but there was no reaction on the screen (is there supposed to be?) and after reboot, all the trial options is still there and I still can't get a reaction by doing e.g. ':SYST:OPT:INST SY5ZYQFV4KG7DDZXC27D6Q5RU25M' ... It responds to the '*IDN?' command, so the connection should be fine..
is there some sort of master reset one may apply by some magic key combination or something?
this is really puzzling...
« Last Edit: April 09, 2014, 11:48:24 am by hooverphonique »
Offline neslekkim
  • Country: no
« Reply #3155 on: April 09, 2014, 11:52:52 am »
I newer got an answer when i did the syst:opt:inst xxx, but when I checked on the scope, everything was ok.
« Reply #3156 on: April 09, 2014, 12:41:08 pm »
hmm... that's funny - everybody else says there's supposed to be a progress bar...
regarding uninstall, I just found that issuing ':SYST:OPT:UNINST' provokes no reaction from the scope, but if I issue ':syst:opt:uninstall', a message appears on screen saying all official licenses have been removed  :o
it doesn't change anything regarding installing licenses, though..
« Last Edit: April 09, 2014, 12:53:20 pm by hooverphonique »
Offline alank2
« Reply #3157 on: April 09, 2014, 01:15:35 pm »
I think there may have been a timer added if you try to add too many licenses, at least I saw some evidence of this in some of the text strings in one of the newer firmware versions.  You may have to leave it on for awhile to get out of that timer (which may also deplete your trial options).
Offline mrflibble
« Reply #3158 on: April 09, 2014, 02:05:37 pm »
And while you are at it ... take notes and write down times and stuff. If in fact Rigol did add some counter measures (unconfirmed hypothesis AFAIK), chances are fairly good that you still have a 100% usable instrument. As alank2 suggests, just leave it powered for a while to let it time out.
Not a direct solution to your problem, but more of a hint when controlling Rigol gear through SCPI. Take both the documentation and implementation with a grain of salt. I like Rigol goodies for the very nice price/performance ratio, but in the department of consistency they are not quite there yet. Basically, don't always belief what the docs say a command should be. In case of doubt best to use the full command in upper case.
And whenever you run into a  :wtf: situation where you are not sure if a command just did what you expected you can check status + logs messages.
Offline Teneyes
« Reply #3159 on: April 09, 2014, 03:17:12 pm »
Try this old trick ,
Set the System Time  to 2099-12-31   23:59;55   and let the Clock roll over.
Then do a Self-Cal.  ( a state that it is in the Factory)
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
Offline Tilman
« Reply #3160 on: April 09, 2014, 03:39:07 pm »
Hello,
300MHZ dosen´t work for my DS2072A only 200MHZ works, any solution?
Thanks
Offline Teneyes
« Reply #3161 on: April 09, 2014, 03:46:00 pm »
Hello,
Thanks
Do you mean you can not Install 300Mhz option?
Try uninstall first, then just Install  300MHz
« Reply #3162 on: April 09, 2014, 03:49:40 pm »
and where do I find those? the DS2000 programming guide doesn't list commands for that, as far as I could see (I didn't read it fully, though)..
Thanks for the suggestion.. unfortunately, it didn't make a difference..
Offline mrflibble
« Reply #3163 on: April 09, 2014, 04:03:37 pm »
Related SCPI commands :
*CLS
*STB?
*SRE?
*SRE <val>
:STATUS
:SYSTEM:ERROR?
Don't have a DS2000. Rigol tends to not document everything, so testing a general SCPI command sometimes gives a useful result, 100% depending on what Rigol decided to implement today.
Offline amr
« Reply #3164 on: April 09, 2014, 08:53:03 pm »
Hello
I've just tried these codes with my new DS1074Z:
DSAB - Advanced Triggers
DSAC - Decoders
DSAE - 24M Memory
DSAJ - Recorder
DSEA - 100MHz
All options have been installed successfully, but 100 Mhz bandwidth option (DSEA) is not shown in the "Installed Options" screen. Is it right?
The firmware version is 00.02.03.SP5
Thanks.
« Last Edit: April 10, 2014, 05:35:53 am by amr »
Offline Suffer1981de
« Reply #3165 on: April 09, 2014, 09:01:13 pm »
Look under Utility -> System -> Sytem Info. If it says its a DS1104Z then congratulations. I used the option DSER which gave me all of the options altogether.
Greetings from Germany
Offline amr
« Reply #3166 on: April 09, 2014, 09:15:52 pm »
Yes!!!! DS1104Z  :) :) :)
I have not used DSER because "DSBA - 500uV Vertical" seems that can cause some software problems...
« Reply #3167 on: April 09, 2014, 09:24:41 pm »
DSER is all options without the 500uV.  ;)
Offline amr
« Reply #3168 on: April 09, 2014, 09:58:03 pm »
Sorry, I meant "DSFR - all options". I didn't know that code (DSER)... :palm:
« Last Edit: April 10, 2014, 05:08:24 am by amr »
Offline LIV2
« Reply #3169 on: April 10, 2014, 02:20:30 am »
So am I the only one with a 1074z with the inability to use some codes?
Are there any other generators besides the riglol online one perhaps?
Offline toni31
« Reply #3170 on: April 10, 2014, 03:37:04 am »
is there any guide of how i install the DSER code?
Offline amr
« Reply #3171 on: April 10, 2014, 05:46:25 am »
Have you tried to install option by option?
I followed these steps (Reply #1345):
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/1335/
Offline LIV2
« Reply #3172 on: April 10, 2014, 09:28:57 am »
Yeah, I've installed everything except Recording and the 500uv vertical codes.
Don't want 500v, but do want Recording.
When I enter a code for the Recording it tells me the key is invalid, I also noticed that the first two sections of this key differ from all the others which were the same.
What firmware are you running? Maybe something's been changed by rigol.
Offline amr
« Reply #3173 on: April 10, 2014, 09:59:22 am »
In my case I have been able to activate that function.
Offline Tilman
« Reply #3174 on: April 10, 2014, 11:00:48 am »
Hello,
Thanks
Yes it Shows "License unavailable", tried uninstalling an installing too.
Had a second one (had an defect) and there the 300MHZ works like a charm
