Chinglish at its best - 'Increase the sanitation function'... Does this mean an upgrade to the flush handle?
KD0RC:
In a way you are correct, but it means that the next time you click on 'Clr Int Cal' you are going to loose the TG completely, NOT just its Calibration. BTW did you ever get your TG Calibration back?
'santitation function' Anyone have any idea what that does?
Increasing the lower TG limit from -30dBm to -20dBm is a downgrade in my eyes.
This is kind of like RPN (Reverse Polish Notaion) because I believe they meant to say that the TG Output lower limit was changed from -20dBm to -30dBm.
Quote@mhwlng, did the bootloader version change with this upgrade? Mine is still at 01.03.bootloader is still 01.03
mhwlng:
Re DSA815 with firmware 00.01.12.00.02: Can you please show us, or describe what the Full Scan (on initial boot-up, or after pressing the Preset button) looks like with the Scan set to to X = Log (for the Log. Frequency display). Thank you in advance.
mhwlng:
Re DSA815 with firmware 00.01.12.00.02: Can you please show us, or describe what the Full Scan (on initial boot-up, or after pressing the Preset button) looks like with the Scan set to to X = Log (for the Log. Frequency display). Thank you in advance.As requested, see attached :
...except that the default TG setting on the example I have here without the "upgrade" is already -30dBm, so I fear they're heading in the wrong direction. For some high gain low noise preamps, -20dBm will be a very strong signal indeed. Yet more external attenuation I guess!
I just checked on mine. I have 01.08 and my TG only goes down to -20dBm. What firmware are you running? The extra 10dB of attenuation would be more valuable to me than a logarithmic x axis (though, I wouldn't turn it down). Is there any definitive word on TG amplitude in 01.12 and whether all the riglol hacks still work?
Thanks!
C:\Users\Me\Desktop\rigup-0.4>rigup scan 32M_MemDump.scpi > keys.txt
C:\Users\Me\Desktop\rigup-0.4>rigup license keys.txt NSEH
rigup license - Version 0.4
ABCEEFG-ABCEEFG-ABCEEFG-ABCEEFG (NSEH = 0x1C087)
C:\Users\Me\Desktop\rigup-0.4>rigup license keys.txt NS8N
ABCEEFG-ABCEEFG-ABCEEFG-ABCEEFG (NS8N = 0x1C0C3)
bfin> bootm
## Booting kernel from Legacy Image at 00800000 ...
Image Name: bf526-0.0-3.16.0-ADI-2014R1-prec
Created: 2015-01-05 2:54:11 UTC
Image Type: Blackfin Linux Kernel Image (gzip compressed)
Data Size: 4415220 Bytes = 4.2 MiB
Load Address: 00001000
Entry Point: 0028cdc0
Verifying Checksum ... OK
Linux version 3.16.0-ADI-2014R1-precybernet-00397-g4d88578-dirty (cn@cynlaptop) (gcc version 4.3.5 (ADI-2013R1-RC1) ) #15 Mon Jan 5 03:54:08 CET 2015
register early platform devices
bootconsole [early_shadow0] enabled
Board Memory: 32MB
Kernel Managed Memory: 32MB
Memory map:
fixedcode = 0x00000400-0x00000490
text = 0x00001000-0x001b6b68
rodata = 0x001b6b68-0x0024939c
bss = 0x0024a000-0x002604e8
data = 0x00260500-0x00284000
stack = 0x00282000-0x00284000
init = 0x00284000-0x00573000
available = 0x00573000-0x01f00000
DMA Zone = 0x01f00000-0x02000000
Hardware Trace active and enabled
Boot Mode: 1
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF526 Rev 0.0
Warning: Compiled for Rev 0, but running on Rev 2
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 400 MHz core clock and 100 MHz System Clock
boot memmap: 0000000000573000 - 0000000001f00000 (usable)
On node 0 totalpages: 7936
free_area_init_node: node 0, pgdat 00281350, node_mem_map 00575000
DMA zone: 62 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 7936 pages, LIFO batch:0
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
External memory: cacheable in instruction cache
Data Cache Enabled for CPU0
External memory: cacheable (write-back) in data cache
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 7874
Kernel command line: netconsole=6666@10.146.248.28/eth0,6666@10.146.248.20/0:30:48:db:6:6 mem=32M
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Kernel managed physical pages: 7936
Memory: 25836K/31744K available (1750K kernel code, 142K rwdata, 586K rodata, 3004K init, 89K bss, 5908K reserved, 1024K DMA)
NR_IRQS:159
Configuring Blackfin Priority Driven Interrupts
Console: colour dummy device 80x25
console [tty0] enabled
bootconsole [early_shadow0] disabled
Calibrating delay loop... 792.57 BogoMIPS (lpj=1585152)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (42 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezbrd_init(): registering device resources
SCSI subsystem initialized
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@7
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01400
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 50
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 31, base_baud = 6250000) is a BFIN-UART
bfin-otp: initialized
brd: module loaded
physmap platform flash device: 00400000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
NOR chip too large to fit in mapping. Attempting to cope...
Support for command set 0002 not present
gen_probe: No supported Vendor Command Set found
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000040000 : "bootloader(nor)"
0x000000040000-0x000000200000 : "linux kernel(nor)"
0x000000200000-0x000000400000 : "file system(nor)"
m25p80 spi0.1: unrecognized JEDEC id ffffff
libphy: bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=bfin_mii_bus-0:00, irq=-1, mdc_clk=2500000Hz(mdc_div=19)@sclk=100MHz)
bfin_mac bfin_mac.0 eth0: Blackfin on-chip Ethernet MAC driver, Version 1.1
usbcore: registered new interface driver usb-storage
musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517
platform musb-hdrc.0.auto: Driver musb-hdrc requests probe deferral
rtc (null): invalid alarm value: 1900-1-14 0:0:0
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
bfin_wdt: initialized: timeout=20 sec (nowayout=0)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 17
rtc-bfin rtc-bfin: setting system clock to 1989-09-14 07:46:22 UTC (621762382)
Freeing unused kernel memory: 3004K (00284000 - 00573000)
dma_alloc_init: dma_page @ 0x008ea000 - 256 pages at 0x01f00000
bfin_mac bfin_mac.0 eth0: Link is Up - 100Mbps/Full - flow control off
random: nonblocking pool is initialized
buildroot login: root
_______________________________________
a8888b. / Welcome to the buildroot distribution \
d888888b. / _ _ \
8P"YP"Y88 / | | |_| __ __ (TM) |
8|o||o|88 _____/ | | _ ____ _ _ \ \/ / |
8' .88 \ | | | | _ \| | | | \ / |
8`._.' Y8. \ | |__ | | | | | |_| | / \ |
d/ `8b. \ \____||_|_| |_|\____|/_/\_\ |
dP . Y8b. \ For embedded processors including |
d8:' " `::88b \ the Analog Devices Blackfin /
d8" 'Y88b \_____________________________________/
:8P ' :888
8a. : _a88P For further information, check out:
._/"Yaa_: .| 88P| - http://blackfin.uclinux.org/
\ YP" `| 8P `. - http://docs.blackfin.uclinux.org/
/ \.___.d| .' - http://www.uclinux.org/
`--..__)8888P`._.' jgs/a:f - http://buildroot.org/
Have a lot of fun...
BusyBox v1.22.1 (2015-01-05 01:17:41 CET) hush - the humble shell
root:~> cat /proc/cpuinfo
processor : 0
vendor_id : Analog Devices
cpu family : 0x27e4
model name : ADSP-BF526 400(MHz CCLK) 100(MHz SCLK) (mpu off)
stepping : 2 (Compiled for Rev 0)
cpu MHz : 400.000000/100.000000
bogomips : 792.57
Calibration : 396288000 loops
cache size : 16 KB(L1 icache) 32 KB(L1 dcache) 0 KB(L2 cache)
dbank-A/B : cache/cache
external memory : cacheable in instruction cache
external memory : cacheable (write-back) in data cache
icache setup : 4 Sub-banks/4 Ways, 32 Lines/Way
dcache setup : 2 Super-banks/4 Sub-banks/2 Ways, 64 Lines/Way
board name : ADI BF526-EZBRD
board memory : 32768 kB (0x00000000 -> 0x02000000)
kernel memory : 31740 kB (0x00001000 -> 0x01f00000)
root:~> free
total used free shared buffers
Mem: 28840 18284 10556 0 0
-/+ buffers: 18284 10556
root:~> ps
PID USER VSZ STAT COMMAND
1 root 592 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [kworker/0:0]
5 root 0 SW< [kworker/0:0H]
6 root 0 SW [kworker/u2:0]
7 root 0 SW< [khelper]
8 root 0 SW [kdevtmpfs]
59 root 0 SW [khungtaskd]
60 root 0 SW< [writeback]
61 root 0 SW< [bioset]
62 root 0 SW< [kblockd]
64 root 0 SW< [bfin-spi.0]
66 root 0 SW [kworker/u2:2]
97 root 0 SW [khubd]
201 root 0 SW [kworker/0:1]
210 root 0 SW [kswapd0]
211 root 0 SW [fsnotify_mark]
325 root 0 SW< [deferwq]
359 root 596 R {busybox} /sbin/telnetd -p 23
365 root 592 S /sbin/inetd -f
366 root 588 S /sbin/watchdog -F -T 20 -t 10 /dev/watchdog
367 root 600 S -/bin/sh
368 root 592 S /sbin/syslogd -n -m 0
369 root 588 S /sbin/klogd -n
370 root 624 S -sh
377 root 592 R ps
Hello!
I purchased a new DSA815-TG, but he base the latest firmware, read thread, I understand that there is no solution to the licenses for these models?
Also a question about a 10Hz RBW, this option is not even officially on sale, and it is needed. These analyzers are doomed? Only sell and change to the old model? Are there any solutions?
thanks in advance
