Author Topic: So I got DP832 today its a love and hate feeling.  (Read 8554 times)
Online diyaudio
« on: April 07, 2015, 08:33:40 pm »
Today I finally received a DP832 lab power supply from Batronix Europe.
After going through all the reviews and possible issues on the forum, I found one rather annoying undocumented issue, the problem is with the banana plugs!! :palm:,
The banana plugs are incredibly hard to unscrew OR tighten (some so tight they feel liked they super glued tight) , this mechanical issue is found on CH-2 and CH-3 (CH-1 is slightly course not too bad, the ground banana plug is OK and probably the smoothest as I can physically spin freely tight the plug. (The way it should be!!)
See attachment. for the following issues.
1) The banana plug hole alignment.. why so much offset on the hole ?
2) The banana plug is slightly skew ..results in the inability to smoothly unscrew or tighten.
In the mean time I used a temporary solution, as the hard banana on the DP832 was hurting my fingers.
Can anyone confirm this issue? should I return the unit?
« Last Edit: April 07, 2015, 08:41:12 pm by diyaudio »
Online rdl
Re: So I got DP832 today its a love and hate feeling.
« Reply #1 on: April 07, 2015, 09:29:44 pm »
Wow, that's pretty bad.
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #2 on: April 07, 2015, 09:39:01 pm »
I don't have that problem on mine.  The connectors are straight and the screw caps loosen and tighten easily.
However the screw caps will always be a bit loose and when loose can look like they are offset a bit... it looks like your plug-in dual connectors fit OK, so it doesn't appear they are *that* far off.
I tend to think perhaps your unit took a whack to the front.  The banana jacks stick out furthest, and a clumsy shipping company could easily kick the box or drop it and cause the damage you're seeing.
If it bothers you - return it.  I've had 2 DP832's and neither had this issue.
It's not always the most popular person who gets the job done.
Online diyaudio
« Reply #3 on: April 07, 2015, 10:18:09 pm »
After a few hours of playing with the unit (burn-in time), the banana connectors seems to show signs from feeling like super glued tight banana plugs to a "course feeling", its still not the best.. but better than before..it looks like they burning-in maybe? (I know this is very unacceptable) but its not detrimental.
I thought so too, it might be a miss handled DHL consignment but those connectors are not as a result of miss handled bend force and looks and feels more like bad QA on Rigol`s side.
I don't think we have a Rigol agent in South Africa? and if the return to Europe is at my expensive, no way I'm paying for that.. I can tolerate a minor issue like this. I've seen worse issues reported here.
« Last Edit: April 07, 2015, 10:21:28 pm by diyaudio »
Offline Stupid Beard
« Reply #4 on: April 07, 2015, 10:22:48 pm »
My DP832 should arrive tomorrow, also from Batronix so it should be from the same batch as yours. I'll let you know if it has the same issue. Hopefully you were just unlucky :scared:
Online diyaudio
« Reply #5 on: April 07, 2015, 10:33:15 pm »
Thanks let us know, yeah unlucky, I didn't imagine the banana plugs would have been an issue. But that's China QA for you.. its like spinning the wheel of fortune.
Offline bson
« Reply #6 on: April 08, 2015, 12:32:15 am »
It looks almost as if the caps weren't threaded on straight...  :wtf:
Offline apelly
« Reply #7 on: April 08, 2015, 12:55:34 am »
More likely it was dropped on its face. They look bent to me.
Mine are fine. I suggest you get a replacement.
I'd rather a Google clue, link, or some theory than "do this" (generally)
Offline smjcuk
« Reply #8 on: April 08, 2015, 10:37:59 am »
Those banana sockets look pretty cheap to me. The plastic doesn't even look fully opaque.
Edit: dropped a TTi PL on the front and nothing happened.
« Last Edit: April 08, 2015, 10:39:33 am by smjcuk »
Offline kayvee
« Reply #9 on: April 08, 2015, 10:42:45 am »
It does like shipping damage, how was the packaging?
Online diyaudio
« Reply #10 on: April 08, 2015, 11:18:39 am »
I cannot comment on the cheap plugs.. but the strength of these plug feels good (I can confirm its very tough and not a standard diameter compared to the loose batch of banana plugs I have on my desk), its as if the plugs hasn't been threaded correctly and the more I screw them and unscrew them they cutting thread. its better than yesterday but still physically feels very course.
Online diyaudio
« Reply #11 on: April 08, 2015, 11:21:40 am »
Packaging was OK. besides the unit has large rubber protective feet on the front and back, the claim of shipping miss-handling is not the issue here, this is a factory QA fault.. I'm trying to ascertain how serious this is. I sent support an email so im waiting for feedback.
Other than that the unit works fine.
Offline blackdog
  • Please stop pushing bullshit...
« Reply #12 on: April 08, 2015, 11:26:04 am »
Hi diyaudio,
This dus not look good...
I think it felt on its face, send it back.
The banana plug hole on these units are a little tight, but all my profesional banana plug's fits, these are Hirschmann and MC brand.
A picture of my unit...
Kind regarts,
Blackdog
“Two things are infinite, the universe and human stupidity, and I am not yet completely sure about the universe.”
« Reply #13 on: April 08, 2015, 11:43:02 am »
My DP832 just arrived, which as mentioned also came from Batronix and so should be the same batch as the problem one.
It looks totally fine to me and there's not any issues with my Pomona banana plug to croc clips. The only double banana plug thing I have is the thermocouple for my multimeter, so I just tried it across all the jacks and there were no alignment issues.
Considering how the thing is packed in the box, I don't think that it could be shipping damage without visible signs on the box itself.
I can take a picture of mine if you want me to, but it basically looks like the one blackdog posted.
Online diyaudio
« Reply #14 on: April 08, 2015, 11:51:42 am »
Hi diyaudio,
Kind regarts,
Blackdog
Hi Blackdog
Looking at your unit the banana plugs looks straight at first glance, straight and no signs of alignment issues (compared to mine). I don't think my unit feel on its face (rubber front feet and rear protects it from issues like this, do note I removed mine, to mount my unit under my desk), I just got unlucky.
Thanks for the update, appreciate the effort.
« Last Edit: April 08, 2015, 11:55:43 am by diyaudio »
Online diyaudio
« Reply #15 on: April 08, 2015, 11:56:42 am »
Thanks for the update, I got unlucky bah!
Offline apelly
« Reply #16 on: April 08, 2015, 01:52:37 pm »
I got unlucky bah!
No. You are making your own misfortune.
There are many, many 832 owners on here that have not had this problem. If your packaging wasn't damaged then I suspect your unit was damaged in some warehouse and repackaged before shipping.
Offline Omikron
« Reply #17 on: April 08, 2015, 06:01:40 pm »
I got unlucky bah!
Nope, it is unlucky.  I had a similar problem with my unit from last month, and an even worse problem with a unit received this week.  I just spoke with Rigol and they confirmed that it's a production issue that they are working on resolving.
Online diyaudio
« Reply #18 on: April 08, 2015, 06:42:39 pm »
I got unlucky bah!
That`s just craziest thing I heard.  Care to elaborate?
Online diyaudio
« Reply #19 on: April 08, 2015, 06:46:03 pm »
Great, I knew someone in the world had such an issue, and this confirms its NOT A SHIPPING ISSUE.
Response from Batronix support,
I am glad you received your device.
I just talked to Rigol about this issue. According to them, this problem should have been solved a long time ago. I am very surprised that this still happens.
They told me that you can easily use a drilling head ( 3,8mm) and carefully widen the plugs. Rigol says this won´t do anything bad to the device.
I am very sorry for any inconvenience caused.
Please let me know if it works.
Seriously? Drill into a new power supply I just bought. WTF? :rant: :palm: :--
« Last Edit: April 08, 2015, 06:50:43 pm by diyaudio »
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #20 on: April 08, 2015, 06:50:51 pm »
Batronix is confused. Their instructions are for a separate issue where Rigol received a set of plugs that were not drilled out to the right tolerances to fit a standard banana plug, it was too tight for larger plugs to fit. This is NOT related to your issue.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline TomThomas
« Reply #21 on: April 08, 2015, 06:54:29 pm »
There is a Rigol Agent in South Africa.
http://www.rigol.com/html/about/contact.shtml
But I would not expect much help... buying somewhere else and requesting locally help...
Online diyaudio
« Reply #22 on: April 08, 2015, 07:01:41 pm »
I agree, I'm thinking Rigol probably attempted to brute force fix all DP832 issues and in the process damaged the threading on the banana screw terminals (on some random units without doing proper QA) Its NOT hard to imagine this...think about the 5V regulator heat-sink issue that made it out the door. its one thing onto the next.
« Last Edit: April 08, 2015, 07:04:58 pm by diyaudio »
Online rdl
« Reply #23 on: April 08, 2015, 07:15:03 pm »
For the too-tight binding post issue it seems wrong that they would recommend just "drilling them out". Don't most binding posts have some kind of protective plating? It seems drilling would remove the plated coating which would lead to possible corrosion or other problems down the road.
Offline smjcuk
« Reply #24 on: April 08, 2015, 08:43:26 pm »
This is usually when I resort to VISA + purchase insurance.
