Buyers typically fit into a few obvious categories, such as "cheap, cheap, cheap", "bargain hunters" and "money is no object".
I think buying "cheap" is a major problem in our current disposable society, so I frown upon that path.
Personally, I am pretty solid in the "bargain hunters" category, which suits me well. I like having quality stuff but don't want to pay for it, so I typically buy used or "broken" or smokin' deals on new.
"Money is no object" appears fine if you have the cash to burn, but it almost always leads to eccentric results where you focus too much of your buying power in one area.
The DE-5000 is really the lowest you should go if shopping for a new LCR meter. Trying to reach $50 instead of $100 is just not worth it. If you're really that poor or tight, then just use your scope and function generator to calculate your inductors and capacitors!
Best place to buy is eBay, as there are a lot of sellers from Japan offering a wide variety of optional accessories.
Also in my opinion, a leading cause of TEA is not spending the money when you should, so you buy something that is just good enough but then the shortcomings become evident, so you have to buy something better. Now you have two! Just buy the better gear the first time.
The low-hanging-fruit really strikes me as that old handheld DMM, so I still vote for trying to get something modern. The BM869s is great, but a close second in this case could be the BM829s if you're not a volt nut and want to save $60.
dBm specs:
"At 600 Ohms, -11.76dBm to 54.25d8m,
Accuracy: ± 0.25dB + 2d (@40Hz - 20kHz)
Input Impedance: 10M Ohms, 50pF nominal
Selectable reference impedance of 4, 8, 16, 32, 50, 75, 93, 110, 125, 135, 150, 200, 250, 300, 500, 600, 800, 900, 1000, 1200 Ohms"
$147.98 (USD) delivered:
https://www.welectron.com/Brymen-BM829s-Multimeter_1
