Author Topic: software for HP-33120A generator ?  (Read 254 times)
Offline peterp
« on: May 24, 2019, 03:58:57 am »
Hi all,
I've checked that the HP34811A BenchLink Arb software for this generator is no longer available. Are there newer
versions of HP (or other) software that can be used with the 33120A ?
Offline chronos42
Re: software for HP-33120A generator ?
« Reply #1 on: May 24, 2019, 04:26:32 am »
Do you mean 34811a or 33120a?
And for which operation system?
For windows I use this softwarebundle with my hp 33120a:
A software, called: "FuncGen_25Aug_a.exe". This is the main install software package.
You also need the agilent/keysight IOLibSuite with an Agilent USB-GPIB Converter or a NI card with the NI driver. (I am not sure what is necessary for communicatian via serial link)
Further there is a plugin for pulses, "WFE_PulseAddin and a pattern editor called PatternEditorInstall_4.0msi".
This sofware is rather old, but is still working, even with the latest Windows 10 64bit version.
Offline peterp
« Reply #2 on: May 24, 2019, 05:23:04 am »
Thanks for the info.
I think the 34811a refers to the software that is no longer available.
I googled "FuncGen_25Aug_a.exe" ... is it part of the IntuiLink Waveform Editor ?
Offline chronos42
« Reply #3 on: May 24, 2019, 05:50:39 am »
I am not 100% sure but I think it was indeed part of  IntuiLink Waveform Editor.
