Products => Test Equipment => Topic started by: Electro Fan on May 29, 2015, 09:02:55 pm
Title: Solder diameter for SMD
Post by: Electro Fan on May 29, 2015, 09:02:55 pm
Any preferences on solder diameter size for work in the range of 1206, 0805, and maybe some 0603?  Seems like coin toss between .025" and .020"
Title: Re: Solder diameter for SMD
Post by: wraper on May 29, 2015, 09:12:42 pm
I prefer to use 0.25 mm for evreything small SMD. Though for <0402 even this feels too thick. 0.5mm for small to average through hole jobs.
Post by: Rerouter on May 29, 2015, 09:15:36 pm
0.8mm with a 1mm conical tip works just fine for me, but I've done solder rework 1 hour a day for years now, so it could just be that i am used to it,
tack one corner, swipe along the other before the flux boils off,
Post by: slurry on May 29, 2015, 09:23:47 pm
Sometimes 0,25 but mostly 0,65mm (0,62 or 0,63 depending on manuf.)
i think it is much easier to work 0805 with thicker than thinner due to higher flux content, many of my old colleagues also prefer thicker than thinner for the same reason,
0402 is a bi*ch with anything but tinned pad, heat and liquid flux.. 0603 is ok with 0,25mm.
No thin tips for me, chisel for quick heat transfer and work fast instead  :)
Post by: zapta on May 29, 2015, 10:11:03 pm
I recently switched from 0.5mm (20mil) to 0.38mm (15mil) and love it. It flows better, doesn't have that flux-less mushroom head and easier to control. It's now my standard solder wire and I use it also for through hole (e.g. 0.1" headers).
http://www.digikey.com/product-detail/en/397982/82-131-ND/2498929 (http://www.digikey.com/product-detail/en/397982/82-131-ND/2498929)
Post by: Electro Fan on May 29, 2015, 10:24:31 pm
Thanks for the replies.
For starters, seems like it's good to get our inches and millimeters squared away  :)
So far it seems like some people like larger diameters .031"/.8mm and .025"/.63mm to get more flux, but zapta likes .015"/.38mm better than .020"/.5mm
It's kind of on the fence....
Post by: georges80 on May 29, 2015, 10:50:24 pm
Solder diameter doesn't really affect anything for SMD work. There's usually more than enough solder still on the tip to do the job to at least 0805 size. I just keep the tip well tinned and use liquid flux to do the job. My solder spools are 0.025" and 0.031" diameter (RMA and No Clean) fwiw.
The KEY is decent liquid flux. RMA flux works great, though must be washed. No Clean fluxes are ok for rework but not nearly as nice (from my experience) as RMA. I have a bottle with tip dispenser filled with both variants.
cheers,
george.
Post by: Psi on May 29, 2015, 11:12:35 pm
0.3mm for SMD
0.7mm for TH
Post by: T3sl4co1l on May 30, 2015, 02:23:18 am
~30 mil (1/32", 0.75mm) is fine if you're careful (use a light touch) and aren't doing smaller stuff (0603, TSSOP, etc.).  The bulky 0805+, SOIC, SOT, etc. is all easily done that way.  Yeah you might put on big globby pads from time to time, but that doesn't hurt too badly.
I currently use 20 mil (0.5mm), anything around there I would consider fine for any leaded part.  I would dare say, anything smaller than that would be irritating to use, as it would contain so little solder per length that you have to use a real pile of it when you have to do through-hole pads.  It's annoying enough to solder a big >1.5mm i.d. pad with this stuff, I use several cm at a time!
There are oodles of tinier packages, but that's the thing, they're tiny, and usually buried type (LGA/BGA), practically unsolderable.  You want paste and reflow for those.
Speaking of paste, it is handy to do TSSOP/QFN scale stuff, even with an iron.  I certainly wouldn't call it a necessity nor a game-changer though.
Tim
Post by: nanofrog on May 30, 2015, 03:50:45 am
For 1206 & 805, you'd do well with 0.20"/.51mm, though if you've good eyesight, steady hands, and sufficient lighting, .025"/.635mm works as well (very easy to over-add solder). Once you hit 0603, you might seriously want to switch to .015"/.40mm if your eyesight and steadiness of hands is meh (.020" works for good vision & solid hands).
Chisels work better than conical for most point to point passive SMD's, though a very fine conical has it's place in sticking down single IC legs to hold it in position before drag soldering.
As mentioned, plenty of flux is definitely your friend, so go for quality supplies with enough flux inside (i.e. 3% flux content by weight). And if you need more (definitely will with drag soldering), don't be shy; add it.
Stick with brands such as Kester, AIM (American Iron & Metals), Multicore (Henkel), Alpha (Cookson), Indium, MG Chemicals, Techspray, or Stannol (flux, solder, & desolder wick). FWIW, buying additional flux in liquid form (bottles) is more economical than disposable pens.
Post by: Smith on May 30, 2015, 07:24:15 am
I mostly use Stannol, Multicore and Felder.  Ranging from 0,23mm (0,009) for small SMD (0402) upto 0,7mm (0,028) for very large connections  like relays, thick wires etc. I mostly use are 0,3 and 0,5mm, wich works great for troughhole and SMD upto 0805.  I have standard solderstations, so going smaller than 0402 would need some special gear.
Post by: MrAureliusR on June 02, 2015, 05:08:40 am
I've used Kester for a long time now, and not only does it work really well (I find it's miles better than the MG Chemicals stuff our school uses) I really love the smell of it! I know it's crazy and I try not to breathe it in, but when I use other solders they just smell gross. I wonder why this is... I don't even think it's a conditioning thing, because I remember noticing it the first time I bought a roll.
I bought two 1LB rolls, one of .6MM, one of .015" (can't remember what that is in MM) and after a LOT of soldering over a couple years it feels like I've hardly put a dent in them. About ~$40CDN ordered online, slightly more at the shops here in Canada, but well worth it if you take your soldering seriously.
(I'm not really a Kester fanboy -- Multicore, AIM, etc all work just as well, and MG Chemicals make really great chemical products, I just don't like their solder)
Post by: nanofrog on June 02, 2015, 08:50:53 am
Differences in the flux type (synthetic resin no-clean v. rosin based product for example)?  :-//
...MG Chemicals make really great chemical products, I just don't like their solder.
FWIW, I find their solder to be too expensive IME (i.e. 1/2lb rolls cost as much as 1lb rolls in other brands). So I skip it for personal use. Wire diameter offered is limited as well (i.e. only go down to .032" when you want smaller).
I still mention it however, as it's the type of product you can use it to pad an order to meet a free shipping requirement or minimum order amount without sacrificing performance (no other brands available, or are too expensive on 1lb rolls).
As you say, their chemicals are good, and the Rosin 835 is an amazing deal for hobbyists IME (excellent performance, and a lot cheaper than disposable pens).  :-+
Post by: mikeselectricstuff on June 02, 2015, 09:05:33 am
Can anyone recommend a good leaded 0.3mm (or smaller) solder at a sensible price ?
A few years ago I bought some Hozan H-712 in Tokyo which is excellent. More recently I got some "Best" brand from Ebay which is horrible - nasty dull joints.
I notice there are now quite a few brands on ebay - anyone found any good ones?
Post by: Kibi on June 02, 2015, 10:17:08 am
Stannol do a lead alloy 0.3mm solder. I have not used the 0.3mm variant myself, but the 0.7mm that I have used is fine.
Rapid appear do appear carry it, although it's got a week lead time on it at the moment.
http://www.rapidonline.com/Tools-Equipment/Stannol-Solder-Wire-HS10-Sn60Pb39Cu1-0-3mm-100g-50-3996/?source=googleps&utm_source=googleps&IncVat=1&gclid=CO-Y9cjh8MUCFTPMtAodCDQASQ (http://www.rapidonline.com/Tools-Equipment/Stannol-Solder-Wire-HS10-Sn60Pb39Cu1-0-3mm-100g-50-3996/?source=googleps&utm_source=googleps&IncVat=1&gclid=CO-Y9cjh8MUCFTPMtAodCDQASQ)
Post by: nanofrog on June 02, 2015, 10:24:03 am
Not sure of what you're after as a sensible price (what I saw on Farnell was horrifying), but the following might be of interest.
Post by: nctnico on June 02, 2015, 10:29:12 am
For me anything from 0.5mm to 1.5mm works from 0402 sized and bigger.
Post by: DaveW on June 02, 2015, 07:24:33 pm
This stuff is lead free but solders really nicely, doesn't ball up much either so you can get really small amounts of solder on joints. We use this for prototyping at work and can easily get IPC class 3 joints. Looks expensive, but that reel will last forever,
http://www.somersetsolders.com/almit-020mm-ultra-fine-lead-free-solder-wire/p2 (http://www.somersetsolders.com/almit-020mm-ultra-fine-lead-free-solder-wire/p2)
Post by: alank2 on June 03, 2015, 01:44:39 am
I typically use Kester water soluble 60/40 .031 for most things.  I have some .015 of the same stuff, but it seems so thin that the flux doesn't seem to do much...
Post by: nukie on June 03, 2015, 03:13:36 am
I find the Japanese stuff much easier to use in smaller diameter wire like Almit and Nihon Superior.
Post by: wreeve on June 03, 2015, 06:46:50 am
Mike,
FUTURE HF FAST FLOW 2% 0.315mm/30swg ALLOY 63/37. By far the best solder I have ever used by a mile. Use it every day on 0603 and even leaded, just feed it in! By a spooky coincidence I have just bought another 250g reel which lasts me for about 8 years! Bought direct from Warton Metals.
Post by: TheAmmoniacal on June 03, 2015, 06:51:20 am
I swear by 63/37, 0.3 mm. Lowest melting point and fast solidification!
Post by: wreeve on June 03, 2015, 07:18:07 am
and less flux to clean as it's more targeted!
Post by: tautech on June 03, 2015, 07:20:52 am
Similar here too, 0.9 - 1.2mm, although I mainly stick with 0805 and SOIC, but I'd happliy go to 0603.
Post by: RobertHolcombe on June 03, 2015, 07:44:13 am
Multicore C511 0.35mm and 0.56mm, depending on component/lead size, and/or the task.
Post by: JackP on June 03, 2015, 07:35:18 pm
Spent a few days soldering THT last week with a 936 clone, conical tip and cheap .3mm solder. What I've learned, get some bigger stuff (and order in some new chisel tips!). The amount you had to feed in was ridiculous!
Post by: mikeselectricstuff on June 03, 2015, 08:30:42 pm
Yes - I use 0.8mm for most stuff but there are times when it's just too much, like touching up QFPs after braiding off shorts, 0402s etc. and that's when the 0.3 comes out .
