Doesn't the 8505/6 famously have a 7.5 digit 10V range? That would make 1uV resolution ambiguous.
It appears to, when averaging is enabled, but as I observe it in action I think that last digit may have missing codes. IOW, it can't display all possible values. For example, as it drifts around, I see 10.00000 0, 10.00000 1, 10.000004, but never 10.00000 2 or 10.00003. I haven't explored this at all, just a quick observation.
I get the full compliment of numbers in averaging mode.
It sounds like the A/D converter may need trimming, if it is missing codes (all the steps are adjustable...)
That is serious project, though. The manual explains it, but you need a ton of precise equipment and it is still an iterative process... (I have never attempted it.)
I'm thinking that today, it ought to be possible to do something over GPIP to automate measuring the A/D performance, but haven't actually tried anything...
Regarding stability in general, I once did a test where 4 of these meters were left running overnight reading an EDC VS-330 voltage reference (which has been "massaged" with some better components here and there to improve stability) set to 10V.
Over the 8h period, the four meters and the VS-330 tracked each other as follows:
DMM1 +/- 1.2ppm
DMM2 +/- 0.5ppm
DMM3 +/- 0.6ppm
DMM4 +/- 0.85ppm
This was at night, during the summer, where the temperature is very stable overnight in this location.
I just used the Peak function on the meters for this, so I don't have any logs.
Bottom line, this old school stuff is all "good enough for Australia" when in good shape and given a quiet place to work!
