I did some measurements on different locations in 7081 using HP3457A, and unless otherwise specified, the LO terminal of the 3457 is connected to the TP305. I found that +10V Ref or -10V Ref has very low frequency oscillations, but 20V(+/-10V ref) is not, 0V(IC306 Pin2 to TP305) is not either.
HP3457A (Divider Buffer), S7081(7*9 short input) +10V Ref, Powered ON, Temp=1N829, RoomTemp≈19C
HP3457A (Divider Buffer), S7081(7*9 short input) R351 left side, Powered ON, Temp=1N829, RoomTemp≈20C (this pic may have some scale mistake)
HP3457A (Divider Buffer), S7081(7*9 short input) Volt drop of R351, Powered ON, Temp=1N829, RoomTemp≈20C
HP3457A (Divider Buffer), S7081 1N829 Volt, Powered ON, Temp=1N829, RoomTemp≈20C (The time this one took was too short)
HP3457A (Divider Buffer), S7081(7*9 short input) Volt drop of R304, Powered ON, Temp=1N829, RoomTemp≈20C
HP3457A (Divider Buffer), S7081(7*9 7V input) IC351 Pin7, Powered ON, Temp=1N829, RoomTemp≈20C
HP3457A (Divider Buffer), S7081(7*9 7V input) +/-10V Ref, Powered ON, Temp=Not Care, RoomTemp≈19C
