I finally received the DPO4104, it has self test errors (see another thread on Repair section) but the scope seems to work pretty ok. so far I have not been able to find out what problem those errors cause
However, I want to enable the options and I had read all the MDO and DPO 3000/4000B/4000C hacking threads. Now that I have got the scope
I can see none of those methods and techniques are applicable really
Let's say I generate the key with python script, then what? There is no place in this scope to enter any key
Let's say I use the module programming, then what? there is no place to "transfer" the license to the scope
so, unless there is a way to program a module (with a new larger EEPROM) with several options (similar to TDS3000) then I cannot see how these scopes can be hacked really.
Is there any way to do it through the SCPI commands? Telnet?
