Switchable internal 50 ohm terminations are nice but their lack does not bother me much. Feedthrough attenuators are acceptable to at least 200 MHz and usually 300 MHz.
I like having a standard 0.1" pin header for the logic inputs but only if the specifications are provided to directly interface to it and make third party probes.
I am dubious of the BNC mounting arrangement. They should either be physically restrained by other than the printed circuit board or the printed circuit board should include strain reliefs. This goes double when as shown in the video, the feet are designed to tilt the instrument back for ease of use which places more stress on the font panel connectors. Tektronix is particularly bad about this with their huge TekVPI interface boxes.
It lacks differentiation and FFT phase results. This is especially egregious since it includes a waveform generator.
The logic inputs do not support negative TTL or CMOS. What was gained by limiting the negative threshold range to such a low value?
The glossy LCD with massive glare is completely unacceptable.
