With this one not, but we got several supplies from EA, good quality though, the last we´ve bought from them was a 0-80VDC/3KW supply.
But they´re two annoying things on it, which could be also appear on this you´ve linked here.
Booting time (...god, this is a supply and you have to wait a little bit after turning it on) and last state memory - If you switched it "hard" off but don´t switch off the output before, on the next "hard" turning on, it will switch on the output automatically...Sometimes not so good.
