I bought this "millivolt source" very inexpensively on eBay mainly to salvage low EMF tellurium copper binding posts. This seemed 5 times cheaper than buying new.
In fact it turned out to be a precision voltage divider that is still spot on and usable down to microvolts.
On the inside it is full of precision wire wound resistors.
I can also see connectors marked Br1, Br2, Sw1 and Sw2 and it might be a bridge of some sort. Even after partially reverse engineering circuit diagram I still cannot figure out how to use them.
The device seemed to be made by James Biddle, but I cannot find anything similar from James Biddle online.
Would anyone know what it is? Are there any documents available? Thanks.
Sent from my iPhone using Tapatalk
