You must read in the flash memory. This can be done with the following SCPI commands:
:SYST:FRE? 0,1048576
:SYST:FRE? 1048576,1048576
:SYST:FRE? 2097152,1048576
:SYST:FRE? 3145728,1048576
You have to send me the binary data. You can also use my program, it is linked under my profile.
Enclosed is a script that you can drag and drop into the program. It saves the content of the Flash and FRAM.
I can take a look at the data to see if it can be corrected. On my website for the program you will also find the e-mail address to which you can send the data.
Peter
