Author Topic: BNC Adapter Probe to BNC Quick Plug for RIGOL PVP2150 Probe  (Read 643 times)
Offline 2XTopic starter
  • Country: gr
Hello,
I want a BNC Adapter Probe to BNC Quick Plug that will fit properly in RIGOL PVP2150 Probe. I measured the diameter of the probe with a caliper and it is about 4,3mm. Do you know (anyone have ever try this) if the below ( -1- ) which has 5mm diameter will fit ok? Any suggestions are welcomed.
RF Adapters - In Series BNC Adapter, 5mm (non-terminated) -1-
https://gr.mouser.com/ProductDetail/Cal-Test/CT2708?qs=%2Fha2pyFaduil9aKKzx25pi5mjlqy6xB4Xhlq2jKVKQM%3D
Oscilloscope Probe for HF Tektronix,Agilent BNC Adapter Probe BNC Quick Plug DT -2-
https://www.ebay.com/itm/184736275973?hash=item2b0323de05:g:p9UAAOSwNBNgY-5a
I want to connect this at the below adapter:
BNC FEMALE T O DOUBLE BAN PLUG -3-
https://gr.mouser.com/ProductDetail/Pomona-Electronics/1269?qs=2nDnb8a6ouOGU0H3lmGx4Q%3D%3D
